An impact wrench is the easiest way to get the bolt off. If an impact wrench is not available, try having someone put the vehicle in gear and stand on the brakes while you loosen the bolt.
On some other cars, some use deep socket, a long breaker bar to the ground, then bump the starter...make sure your rotation of the engine will loosen it!
Thanks for the help Im going to try these ideas just need to know if the bolt threads to the left or the right.I know the motor rotates clock wise,does the bolt thread the same way.Thanks for the help,this is my first timing belt change and its giving me hell.
i am in the middle of my 96 2.3 timing belt job now, my Ingersol Rand 1/2 inch gun wouldnt take the bolt out, so i took a breaker bar and put on the frame and turned the motor over and it came loose, and i needed a puller to remove the balancer. I replaced the tensioner also, when i would put pressure on the belt it would keep jumping a tooth off on the crank, but i finally got it all lined up.
what kind of gear puller did you use im trying to get mine off my 95 right now and cant seem to doit? was it a claw type or what? my balancer only has 2 holes that are right next to eachother so i cant use the kind that just screws bolts into it and pulls it off and i have no idea how to get the balancer off.
Take washer off bolt and thread it back in the end of the crank. Takes a few extra seconds, but it's way less time than trying to fix the threads inside the crank cause the puller messed them up.
