Power Window Switch
Old 04-18-2008, 07:57 AM
silvergirl's Avatar
silvergirl
silvergirl is offline
Power Window Switch
I need to replace the power window switch in my 2006 Ford F150 truck. my question is,can anybody instruct me on how to do this. or refer me to a site when i can get the instructions(for free) on how how to replace the power window switch? thank you.
Old 04-18-2008, 08:15 AM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Which side? Either side really just consists of removing the bezel that the switches are mounted in then removing the wiring harness and pressing the tabs on each side of the switch to push it back through the top of the switch bezel.
Old 04-18-2008, 10:12 AM
SteveVFX4's Avatar
SteveVFX4
SteveVFX4 is offline
yeah, that bezel around the switches simply pops off from the door panel. I can pop off mine by hand instead of using a screwdriver or something to pry it off.
Old 04-18-2008, 04:38 PM
newt79-99's Avatar
newt79-99
newt79-99 is offline
If it is a 2006 and still under warranty, just take it to a Ford Dealer, that fixed mine real quick.
Old 04-19-2008, 12:07 PM
silvergirl's Avatar
silvergirl
its on the Driverside. And my warranty has expired.
Old 04-22-2008, 06:31 PM
damone's Avatar
damone
damone is offline
You might consider replacing it with one of those switches liek the drivers window (push once and it goes all the wya down. If it needs replacing why not?
Old 04-22-2008, 08:26 PM
FTE Trigger
I thought all the newer 150s (and other models) w/the Power convenience groups came with the 1-touch express down feature for the driver side?
Old 04-23-2008, 06:47 AM
silvergirl's Avatar
silvergirl
when i push the switch for the window to go down,it works fine.But its not having any real contact when i push the button to go up.
Old 04-23-2008, 07:21 AM
5 Star Tuning's Avatar
5 Star Tuning
5 Star Tuning is offline
Former Vendor
We have 2 F150's between those, I have replaced 3 switches... Very easy to do ...Pop the bazel off ; disconnect wiring harness, pull old switch out , install new swtich and reattach wiring harness ; put bazel cover back on...Done!
Old 01-14-2009, 08:19 PM
ayrshirenutter's Avatar
ayrshirenutter
ayrshirenutter is offline
very common on these years.if you get the switches out and seperate/split the box you can pull the button out remove the little peice of metal and bend it then replace,I just done a friends and it works perfectly now.if you don't feel competent then you have to buy a new switch.
Old 07-04-2010, 12:33 PM
JimDon's Avatar
JimDon
JimDon is offline
It's easy to replace like the other post say's remove the bezel unplug the electrical connectors and install the new switch. I took my switch apart and cleaned the contact and it works like new. We have a 2005 and 2007 F150, both trucks had the problem. Ford has installed a defective switch and Ford should remove and replace for free. I did alot of research on this, it is a huge problem but since its not a safety issue Ford will not do anything. The switches usually give intermittent problems until after the warranty period expires and then the switch completely fails. Was this the design or coincidence?????? Anyways you can remove and replace with no tools in 10 minutes if you have the new switch in you hand. You can take the old switch apart and clean the contact in an additional 20 minutes and then you dont have to spend a penny to fix it.
Old 07-04-2010, 04:19 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
XL1200LTD-Keith is offline
Old 07-12-2010, 07:29 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
My 05 drivers side occasionally has a hesitation, so I figure its just a matter of time. i have a warranty with a $50 deductible. I would assume the switch is cheaper than this. But with a dealer item, who knows.
Old 07-13-2010, 06:31 PM
SCRWDRVR's Avatar
SCRWDRVR
SCRWDRVR is offline
"Obsessed"
The switch is 55 bucks I just did mine for the same issue.....
Old 07-13-2010, 07:01 PM
baitmaster's Avatar
baitmaster
markup?
So I'm guessing the markup on these switches is about 800%? Maybe someday I might have to install a $2 toggle switch...
Quick Reply: Power Window Switch
