6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 6.4 mpg improvements
Old 04-17-2008, 02:19 PM
jackpine's Avatar
jackpine
jackpine is offline
Have 13000 miles on my new 08 6.4 and currently getting between 13 city to about 19 hwy running empty. Has any one used aftermarket air filters, chips, etc. to improve milage and do they really help much? Do I need to get more milage on this engine to really tell true mph? Thanks.
Old 04-17-2008, 02:27 PM
nordberg's Avatar
nordberg
nordberg is offline
you have enough miles on it where you could consider aftermarket products. but you mpg sounds better than most. you could look into spartan and innovative diesel. theres a guy on ford-trucks.com selling his badp tuner with dpf delete for 700. his names pahrump, he's also on the diesel garage. intake wont gain much besides setting a check engine light.. my dealer cleared mine but it came back on the same day. but i like the way it sounds and performs. hope this helps
Old 04-17-2008, 04:45 PM
powerstroke1350's Avatar
powerstroke1350
powerstroke1350 is offline
people who cut the dpf have seen big mileage improvements.
Old 04-17-2008, 06:16 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
SouthTexasDiesel is offline
Yep, I was getting 23 mpg in my dually yesterday. DPF delete is the only way to go when you want big MPG gains.
Old 04-18-2008, 08:44 AM
fordfish's Avatar
fordfish
fordfish is offline
Originally Posted by nordberg
you have enough miles on it where you could consider aftermarket products. but you mpg sounds better than most. you could look into spartan and innovative diesel. theres a guy selling his badp tuner with dpf delete for 700. his names pahrump. intake wont gain much besides setting a check engine light.. my dealer cleared mine but it came back on the same day. but i like the way it sounds and performs. hope this helps
13K...How many miles should a 6.4 have on it before you loose the "green piece" and reprogram??? I've got 6500, I am ready to do it now.
Old 04-18-2008, 08:58 AM
jackpine's Avatar
jackpine
jackpine is offline
6.4 milage inprovements
Thanks all for the feedback. got one more question (I'm a new diesel owner and love the truck). Anyone used synthetic oil in their 2008 6.4? Any
brand recomendations? Thanks again.
Old 04-18-2008, 11:10 AM
richamato's Avatar
richamato
richamato is offline
I used AMSOIL at my first oil change, and have had no problems. I also saw a slight (.5 to 1 mpg) improvement with it.
Old 04-18-2008, 11:41 AM
Moyerboy's Avatar
Moyerboy
Moyerboy is offline
i have had an increase sending my 08 up to 15 mpg and if the dpf is the way to get mpg were do i sign up for removal. I have heard of the performanc increases but idk if they are worth it when th eprice of fuel is going up
Old 04-18-2008, 01:25 PM
Ricohman's Avatar
Ricohman
Ricohman is offline
Wow, that is fantastic fuel economy.
And from a dually even better.
You must be able to go a long ways on a tank of diesel.
Old 04-18-2008, 03:15 PM
Foamy's Avatar
Foamy
Foamy is offline
Firstly applogies for being so dumb, but what is dpf.
Secondly "it sounds to good to be true" if removing this thingy gets such a huge mpg improvement, why is it there in the first place, what's the downside.
Can I get in on this trick with my 2004 E450 RV powerstroke getting 10-11mpg?
pugster's Avatar
pugster
pugster is offline
Not much change here
I'm sitting on 14k miles right now. My mileage hasn't changed much from 4000 miles
Old 04-18-2008, 03:17 PM
mlh1's Avatar
mlh1
mlh1 is offline
I use Mobil DELVAC 1 in my 6.4. I to had a .5 mph increse, when I switched. If you do the math you will see that switching to synthetic oil you will save $130 every 10000 miles if you are geting 12 mpg. FREE oil and better procetion too. What a deal.
Old 04-18-2008, 03:36 PM
SouthTexasDiesel
The DPF is a Diesel Particulate Filter; it's the reason the new diesels do not blow any smoke. It's required for all new diesels by the EPA, which is a bunch of BS because it killed the mileage on these trucks. It's a filter on the exhaust system that collects 99% of the soot made by the motor, once it's full the truck will then enter a regeneration cycle which means more fuel is pumped into the motor to create enough heat in the exhaust to burn off the soot collected. Regeneration EGT's at idle will exceed 1200*F.
Now removing the DPF does 2 things. It's reduces the back pressure to 1/100th the pressure it was previously with the DPF, and it removes the regeneration cycle. Both save fuel and the end result is good mileage gains.
I've always gotten exceptional mileage in my truck, mainly because I ordered my truck specifically for towing and mileage. I've got the weight capacity of a 1-ton dually, with the fuel efficiency of a manual with 3.73 rear gears. But overall with the DPF delete I got 15%-20% better fuel mileage than before. And next week when I put on a 5" complete turbo back system I expect the numbers to go up even more.
Old 04-18-2008, 03:44 PM
Foamy's Avatar
Foamy
Foamy is offline
dpf question answered
Thanks SouthTexasDiesel for explaining the dpf for me.
It sounds logical to me, but if I understand correctly taking the dpf out makes the truck a polluter again (Personal choice).
I assume it has to go back in for the emmissions test.
It creates 100X more back pressure !! This sounds like an ideal opportunity for a better aftermarket filter sytem to be developed?
Old 04-18-2008, 03:48 PM
richamato's Avatar
richamato
Thanks, that was a good reply. Unfortunately, most of us out there are not diesel mechanics. How diffucult is it to do the DPF delete, and do you need a programmer to do it?
Quick Reply: 2008 6.4 mpg improvements
