Valve tool
Old 04-17-2008, 12:07 AM
fixnair's Avatar
fixnair
fixnair is offline
Valve tool
Anybody know where I can get a tool for removing valves & springs from a flathead V8 Ford? And about how much does one cost?
Just started on my '52 F1 frame up.
Old 04-17-2008, 07:07 AM
kotzy's Avatar
kotzy
kotzy is offline
Since your working on an after 1948 engine I think a regular valve spring compressor will work. The bar was used to pull tension off the spring to pull the guide lock. Since removal of the keepers will release the pressure against that lock on the later design their removal is easier. If the guides are not worn you may as well leave them alone. kotzy
Old 04-17-2008, 08:08 PM
Kazoo's Avatar
Kazoo
Kazoo is offline
They seem to come up on E-Bay quite regularly. Just type in Ford Flathead and all kinds of goody's come up. The ones I have seen are usually reasonably priced.
Old 04-17-2008, 10:27 PM
effie_man's Avatar
effie_man
effie_man is offline
ya what he said
Old 04-18-2008, 12:39 AM
51ford fan's Avatar
51ford fan
51ford fan is offline
Valve Guide Removal Tool
Click on the text above, (Valve Guide Removal Tool) to go to Speedways Site. I hope this helps
Old 04-23-2008, 09:11 AM
55 f350's Avatar
55 f350
55 f350 is offline
i used a small valve spring compressor from a small engine i'll have to find the part numbers for , but it worked to change two guides and etc. with the flatty still in the truck .
Old 04-23-2008, 07:59 PM
fixnair's Avatar
fixnair
fixnair is offline
Thanks for all the replies. I used the info from 51ford fan and ordered a book and the valve tool.
BLK79
12-19-2016 02:14 PM
GooeyGus
Washington Chapter
04-24-2016 06:24 AM
Leroy Axe
2004 - 2008 F150
09-17-2015 07:43 PM
embry1123
03-17-2010 07:45 PM
Skagit
04-29-2003 08:30 PM
Quick Reply: Valve tool
