Pourable liquid shortening for bio-diesel?
Old 04-11-2008, 09:05 AM
CruiserClass's Avatar
CruiserClass
CruiserClass is offline
I, along with two other guys, are setting up a bio-diesel process. The three of us are sharing set up costs, labor, etc and then fuel are diesel trucks. I'm driving a 1999 F-250 with the 7.3 Liter, the other two drive Dodge Rams of about the same year with the Cummins.
Anyway, a local fish resteraunt has all the WVO we'll need and is willing to give it to us, but the potential problem is what they use isn't labeled as oil. It's "Creamy pourable shortening" and is liquid at room temperature.
Canola Harvest® - Products | Food Service
This link is for a different brand but the same thing.
Can you use this to make bio-diesel at home just like you would regular veggie oil?
Old 04-11-2008, 09:29 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Yes it will work just fine, but will have a slightly higher cloud point than Canola oil.
Old 04-11-2008, 08:43 PM
misnomer's Avatar
misnomer
misnomer is offline
Depending on where you live, if you have cold weather you may find that you want to mix it to BD50 in the winter months. But if it is clear and liquid at room temp when you process it into BD the cloud point will drop 10-20 degrees. People have made BD from pure lard locally and in our hot summers it worked fine but once the temp dropped below 65F their truck started acting like it was starving for fuel when under a heavy load. They mixed it with some diesel and it ran fine, they could have also recirculated their return line fuel which just came from the engine thus is warm, or heat the fuel pickup then run it yearound.
Old 04-12-2008, 12:35 PM
motoman97's Avatar
motoman97
motoman97 is offline
That was just the answer I was looking for as I stopped in a truck stop to ask about their oil. They told me to come and get all i wanted. Show me the kitchen to check out oil. It said on the bottles creamy pourable . I was hoping that it was good.
Old 04-12-2008, 05:03 PM
TchTchr's Avatar
TchTchr
TchTchr is offline
Ditto to above. Make sure to test for caustic fryer cleaners. Fill two liter bottle 1/2 full with oil, another 1/4 with water, cap and shake vigorously. If foaming occurs, there is lye present (not good for engine components). Also, look for thin white streams when emptying jugs - this is fish oil which can clog filters. Have fun and welcome to renewable fuels!
Olds69442
6.7L Power Stroke Diesel
07-25-2012 08:30 PM
DynamoDale
Bio-diesel, Propane & Alternative Diesel Engine Fuels
02-29-2012 11:00 PM
FL450
18
05-13-2008 08:06 AM
MobeyDick
General Diesel Discussion
03-24-2006 06:25 PM
Dieseldan7.3
16
09-12-2005 08:56 AM
Quick Reply: Pourable liquid shortening for bio-diesel?
