is there any quick fix for a burnt valve??
Old 04-08-2008, 08:03 PM
jack048307's Avatar
jack048307
jack048307 is offline
Cool is there any quick fix for a burnt valve??
i got a 1972 302 with what sounds to me like at least 1 if not 2 burnt intake valves. I cant afford a valve job is there some wonder chemical or something that I could use to fix this or does anyone have a spare set of heads for a reasonable price???
Old 04-08-2008, 08:23 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
Wonder chemical? If you consume enough alcohol you might be able to forget about your engine woes for a brief period of time.
How much does a valve job cost where you live?
Old 04-08-2008, 08:27 PM
HemiEater's Avatar
HemiEater
HemiEater is offline
might try the 351W firing order...
Old 04-08-2008, 09:36 PM
Boba Fett's Avatar
Boba Fett
Boba Fett is offline
Start by switching the firing order like HEMI says. If that magically cures it then good
Next check the spark plug wires. So many people mistake a bad wire for a bad engine. Look at the terminals on the ends. Are they green and nasty? Are they seated on the plug ends?
Look at the cap and rotor too for signs of wear.
If you have a few extra wires lying around try swapping them in where you think your problem is.
To find the culprit take a long common screwdriver and place the metal end on the valve cover and headed or manifold port and use the handle as like a stethiscope to listen for the noise valve.
Once you isolate where you think the problem is check that wire and try to swap in one. Look at the plug, etc.
If you determine you have a problem inside the engine then do a leakdown test, or compression test on that cylinder versus another cylinder that seems good and see what you got.
Old 04-08-2008, 09:37 PM
Boba Fett's Avatar
Boba Fett
You can also put the screwdriver on the intake runners near the head too.
Old 04-08-2008, 10:54 PM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
It's very unusual to burn an intake valve. Usually the exhausts burn as they have the hot exhaust gases running over their heads, while the intake valves have the cool intake charge flowing over their heads.
A burnt valve is one in which material is eroded away from the valve face, preventing it from sealing against its seat. I can't think of how any chemical treatment could build this eroded material back up in an assembled engine.
It seems unlikely you could buy a set of heads for less than a valve job. At the old shop I worked at, sometimes frugal people would bring heads in for a quick valve job. If we found any burnt exhaust valves we'd just grab good used replacements from our stash of parts, reface them and install. But the funny part was we'd never tell the owner since if anything ever went wrong of course he'd blame that used valve for it, even though he didn't want to pay for a new valve(s). But we always made sure the good used parts were truly good.
Old 04-08-2008, 10:57 PM
HemiEater's Avatar
HemiEater
why do you think it has a burnt valve..
Old 04-11-2008, 09:24 PM
jack048307's Avatar
jack048307
ok the dizy is new the wires are new the plugs are new the heads were worked over by napa maybe 12-15 years ago i can hear a popping through the carb not back firing its only on the drivers side. I have had nothing but problems with this engine. i wish like hell i had torked that ^&* %@# rod bolt down right I wouldnt be having this problem now. a valve job up here runs 215 + parts but a pair off ebay only runs 270 new
Old 04-11-2008, 09:25 PM
jack048307's Avatar
jack048307
its not worth thowing money at it
Old 04-11-2008, 09:36 PM
jack048307's Avatar
jack048307
I finally after something else went bad found what was causeing the radical change in air/fuel ratio that ultimately resulted in the engine stalling was caused by. "Worn guides can also pass air. "Unmetered" air drawn into the intake ports past the guides creates an effect similar to worn throttle shafts on a carburetor. The extra air reduces intake vacuum and upsets the air/fuel calibration of the engine at idle. The result may be a lean misfire problem and rough idle." I way not have a burnt valve per say, but something is causing a leak that I can hear.
Old 05-30-2013, 03:51 PM
joycben's Avatar
joycben
joycben is offline
My Ford Ranger !!!
Hello All :
My Cousin Has My Ford Ranger Working On It , The Other Shop Didnt Even Pull The Head , They Made A Big Mess !!! My Cousin Said It Has Burnt Valves , Hes Gonna Rework Everthing , Should be Like New , When Hes Thru , Im Not Sure My Self Whats All In Doing This When The Valves Are Burnt , What All Has To Be Changed , Can Anyone Tell Me , Please !!! I Dont Want To Worry Him Right Now !!! The Valves Are Not Bent He Said , But Are Burnt , So With That Said Im Asumeing Its Alot Of Parts And Work !!! He Want Get Paid Until I Get In It And Drive It Over Night At Least !!! Anyones Opinion Please !!! Thanks Bennie !!!!!!!!!!!
Old 05-30-2013, 07:24 PM
Boba Fett's Avatar
Boba Fett
If the vehicle has burnt valves what that means is the valve seats have melted away and when you look at the chambers it will appear thats some of the valves have been sucked into the head.... that is what you should be looking for....
Old 05-30-2013, 07:35 PM
crazy96863's Avatar
crazy96863
crazy96863 is offline
Whats up with the crazy capitalization thing? And you should start a fresh thread in the proper discussion area to get yourself the best responses. Use less punctuation as well.
ford_maniac-68
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
05-17-2016 05:22 PM
FordKld
Modular V10 (6.8l)
02-15-2016 12:05 AM
Manofgod4life
02-02-2016 09:07 PM
jmranchero
03-02-2012 09:17 PM
ncline
06-08-2008 10:31 PM
Quick Reply: is there any quick fix for a burnt valve??
