Fuel pump won't shut off, relay chattering
This is my first post, although I've been browsing and searching this great forum for some time.
I bought my '90 F250 351 4wd E4OD 2 weeks ago for 500 bucks. It ran fine for the first few days, the check engine light was on, but no problems.
Then it began. It would start fine, idle fine, no check engine light. But when I put it in gear and go, it would either sputter and stall right there, or wait maybe 30 seconds and sputter and all but stall, check engine light coming on with the sputtering. I barely got it started and back into the driveway. I replaced the fuel filter, and this seemed to fix the problem, the CEL would come on after a few minutes of driving, but there was no change in driveablity.
This lasted for a whole day. The the problem came back, and I noticed that when I turned on the key, the fuel pump would come on, but not go off (no prime for like 2 seconds). After I let it sit for a couple of days, I tried it again. It went away again, the pump would prime for 2 secs and all was well. Then it came back. I found the negative cable from the battery that is bolted to the engine was nearly gone ( hanging by a thread), so I fixed that. It seemed to remedy the problem. But now, week later, and the problem is back with a vengence. Now the fuel pump relay is chattering, along with assorted other relays around the coil, the pump doesn't turn off, and the truck wont even start.
Sorry about writing you guys a novel for my first post, but I figured you needed all the info I had.
Anyone have ideas about whats going on? Seems like its definately electrical, I haven't had much time to work on it yet..
Grant
Grant
