Southwest Region Arizona, New Mexico, Oklahoma, and Texas.
rear differential
Old 04-03-2008, 12:57 AM
danquin1's Avatar
danquin1
danquin1 is offline
rear differential
Does anyone know what is involved in changing the rear diff oil in a 2000 expy, EB 2x4
Old 05-23-2008, 04:34 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
Ya its really easy, First take the cover off and let the oil drain in a pan, make sure that you remove all the gasket from the housing and the cover, now would be a great time to paint the cover just make sure you let the paint dry. Use RTV for the new gasket on the housing let it dry for only 5-10min and bolt the cover back on. The fill plug is on the drivers side front of the Dif housing you can use the 3/8" ratchet to remove the fill plug and add the new Diff oil I would use Royal Purple 75W140 its great stuff and its only $10qt you will need 4qts I believe. If you have any more question let us know.
~Gage~
ChiefGeek
1999 to 2016 Super Duty
08-08-2017 06:12 AM
Bigbruce
04-16-2017 06:01 PM
StockMan
10-30-2001 07:48 PM
PAUL_2
05-25-2001 09:37 AM
roscoe
1978 - 1996 Big Bronco
03-01-2001 05:43 PM
Quick Reply: rear differential
