distributor/cover questions
Thought I would post here first, even if it IS mighty quiet!
I know that there are two front covers, and two distributors. Which is which, how can you tell them apart, will either one of the distributors work with BOTH covers?
Not sure, but I think I have the cover that uses the distributor, that has the "extended" shaft past the gear, but, my distributor doesn't have the long end, just the gear.
Help!?!
R
Help!?!
R
Originally Posted by effie_man
k first off what motor are we talking about here?
This came from Ross, Albuq...<quote>
Yes, you can run the non-extended dizzy in an aluminum cover. Not all aluminum covers had the extra bushing /support at the bottom. It seems to me the Canadian aluminum front covers were straight replacements of cast iron ones, while American aluminum covers were the extended type. Could be wrong here. I'm running a MSD Ready-to-run in a Canadian aluminum (non-extended) cover.
Sorry, I tend to forget Ford made OTHER motors...
R
I had been watching for one of the aluminum ones, and it wasn't until last night, that I realized that I already HAD one!! For some reason, I thought the Canadian ones were the only aluminum...I sure have a LOT to learn! It was already painted when I got it, so I didn't know, until I pulled the dizzy out, then realized that it wasn't "right" for the cover I had, so started doing research...
Sure looks different now - truck rebuilt water pumps, truck fan and mount, new fresh paint, aluminum (maybe) manifold...but, now that all that's done, I doubt if I'll strip the front ALUMINUM (YEAH, BABY!) cover...too pretty to touch...
Thanks all,
Roger
Thanks all,
Roger
manifold is prolly cast but hey, stranger things have happened. nice looking flatty
does that motor have the center sump oil pan or the stepped one?
R
well the truck ones are either a stepped looking pan for 51-53 (I think) trucks and then the 48-50/51 had a center sump with a really large drain plug/cleanout. The car pans are similar tot he 48-50/51 truck pans except they have a small drain plug. My truck had one of these pans on it but had to change to the correct truck pan (53) in order to lower my front end and maintain clearance to my straight axel
I have the truck pan, with the big cleanout that came with my truck (notice I said with and not ON!). The pan had been off forever, full of rusty bolts. This one (I just looked, and took some pics, they'll be up in a few minutes) on it is the car, with the small plug, and hump in the center...
Pics in a minute...
R
Pics in a minute...
R
