Custom building an intake
Old 03-19-2008, 12:36 PM
jwal's Avatar
jwal
jwal is offline
I own a 1999 with the 4.6l. i currently have a k&n filter and after looking at images of their cold air intakes i was thinking of building my own. I have access to a pipe bender and adapters for attaching to the throttle body. has anyone ever attempted this, and if so did you get the same results as a full k&n kit?
i was also thinking of re-routing it closer to the ground to pull in even more cold air, and of course building a shroud to protect it from the heat and dirt.
thanks in advance.
Old 03-20-2008, 10:23 AM
Storm's Avatar
Storm
Storm is offline
Whats the intake size on the 4.6? If its something like 3" you could do it easily.. I fab'd up an intake on my 89 Mustang.. Course this was YEEEEEEEars ago.. Had a 2.3L Turbo from a Thunderbird dropped, used exhaust plumbing to route the filter down lower..
Old 03-20-2008, 10:35 AM
jwal's Avatar
jwal
jwal is offline
thanks for your help. I printed off directions for the installation of a k&n for my truck and i think i can pull it off. exhaust tubing was what i was planning on using also. the only thing i'm worried about is my mass air flow sensor.
Old 03-20-2008, 10:52 AM
Storm's Avatar
Storm
Storm is offline
That's not too difficult.. Just have to drill a hole and flush mount it. Wouldn't be too hard to test.
Old 03-20-2008, 11:28 AM
jwal's Avatar
jwal
jwal is offline
thanks, i honestly never even thought of that. i'm gonna make the intake out of exhaust, wrap it in header tape and insulation then put a polished tube over the outside for appearance
Old 03-20-2008, 11:39 AM
Storm's Avatar
Storm
Storm is offline
Use aluminum exhaust tubing and then polish it
Old 03-20-2008, 07:14 PM
Truckin4life's Avatar
Truckin4life
Truckin4life is offline
Street Queen to the extr3m3
makes since to me. Less work!
trucker01
16
05-10-2014 09:23 PM
littlejohn6977
02-07-2009 10:45 PM
sparkyellis
2004 - 2008 F150
04-14-2008 08:48 PM
homer4.2
3.8 & 4.2L V6
32
07-01-2004 03:00 PM
PSD6litre40
06-07-2004 06:34 AM
Quick Reply: Custom building an intake
