Fire
Old 03-19-2008, 08:32 AM
billfishnut's Avatar
billfishnut
billfishnut is offline
Question Fire
Guys I set up an appleseed in my garage and haven't used it yet. I am wondering if anyone has ever heard of or had experience with a fire due to home biodiesel production.
Old 03-19-2008, 09:36 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
I have not had any fires, but there have been other fires reported, including a commercial plant in Idaho that blew up and killed the owners son. Be very, very carefull...................
Old 03-19-2008, 09:50 AM
billfishnut
Thanks Fabman, I just talked to my insurance adjuster and they said I can do this in my garage and I will be covered if I blow up my place but will be canceled afterward.
Old 03-22-2008, 08:53 AM
TchTchr's Avatar
TchTchr
TchTchr is offline
I was wondering about insurance too if I ever moved my operation to my garage.
Old 03-23-2008, 03:55 PM
AndysFords's Avatar
AndysFords
AndysFords is offline
I had a small fire in my reacotor, only because my dad left the heater element on while he was draining some bio out of the reactor, can you say DUH! Had to dump a bucket of water on it to get it to go out.
Old 03-24-2008, 10:06 AM
nitrogen's Avatar
nitrogen
nitrogen is offline
dumping water on a diesel fire is a good way to spread the fire you were incredibly lucky. i don't have the space to process or i would be doing it, however for those of you who do, you have to remember you are manufacturing "diesel fuel". its supposed to burn really well, and the process involves heat so you really should have large fire extinguisher handy, depending on the size of the operation i would say at least a 10 pounder or even a 50. when fire strikes you're not going to wish for a smaller cheaper extinguisher. many of you who are processing also are involved in other stuff in the shop grinding welding cutting torches hopefully not to near your bd plant but still all good reasons to get good fire suppression devices
Old 03-24-2008, 12:05 PM
evictorwalli's Avatar
evictorwalli
evictorwalli is offline
BioDiesel is a Class B fuel. Use a Dry Chemical fire extinguisher. Even with a dry chem you can spread the fire by pushing the fuel around with the pressure of the extinguisher. Try deflecting it off something.
Be careful of using a CO2 extinguisher in confined spaces it displaces oxygen. CO2 also has a cooling effect and can bring the tempuarature of the fuel below the ignition temp.
Old 03-24-2008, 07:09 PM
fabmandelux
I use all steel tanks with a Nitrogen "blanket" above the biodiesel. This prevents any combustion within the tanks, and also helps prevent oxidation of the fuel.
Old 03-28-2008, 04:23 PM
AndysFords's Avatar
AndysFords
My reactor at the time was a 500 gallon big truck tank turned on end, with the top cut out, and there was only 10 gallons in it, it wasn't going anywhere, the water just smothered it.
SUPERDUTY_untouchabl
Arkansas Chapter
09-21-2007 06:44 PM
badboyblue
Modular V8 (4.6L, 5.4L)
01-03-2003 01:21 AM
TUCK
Texas Chapter
12-01-2002 06:53 PM
Ginntonnik
1978 - 1996 Big Bronco
01-23-2002 06:09 AM
CRJ900
01-18-2002 04:05 PM
Quick Reply: Fire
