White Smoke from Exhaust
happened once if it was especially cold out then it could be your piston sleves and rings were expanding/contracting and some oil probably seeped into the cylinder
for gas motors general rule is white smoke oil in cylinder black too much gas.
if it happened once its probably nothing to worry about. if it happens again i would look for something wrong
Moved to the 6.0L PSD section (assuming this is a 6.0).
07 F250 Aggie Mobile, do me a favor and edit your signature to reflect what engine your truck has. It's nice to know the color but it doesn't help when folks are trying to diagnose an engine problem.
Is the 2006 Super Duty in question a different truck than the 07 in your sig?
Originally Posted by 07 F250 Aggie Mobile
It's only happened once...and only lasted for about 10-15 minutes. Should I be headed back to the dealer??
The EGR cooler on mine has gone out twice in the last year 2005 F250 in the last year it is in the shop right now for the second time the smoke starts out a little then it will come out until the engine warms up eventually it will go out completely then you will see blue smoke along with the white smoke I was told that once the EGR cooler goes the oil cooler will follow hope this helps
Leopold
1999 to 2016 Super Duty
34
12-02-2012 11:43 AM
BRay09
18
08-06-2010 03:48 PM
ztodd377
61
05-18-2010 09:09 PM
