Which prosessor?
Which prosessor?
So if you had to go back and do it again, or if you are just now starting, what prosessor style would you build? Keeping costs down here, not a multi thousand dollar unit, and looking for 100-150 gallon production a month only.
I'm going back and forth between the appleseed and a barrel style. The appleseed seems nice because it's just a bolt together kit, but I kind of want to save the couple hundred and go with a barrel style (I don't want to use a used WH). Are barrel style prosessors just as safe as using a WH?
Ideally, I'd like to find a cone bottom tank, but I know they're pricey.
What would everyone use? Are there some new prosessors I didn't mention that are better?
Check out www.murphysmachines.com (I think) to see his processor - the plans cost about $100 but they look to be VERY detailed and it sounds like Murphy is really helpful. He also has plans for a nice wvo collection system "Super Sucker" I think is what its called. Also, another good site to explore is www.journeytoforever.com.
Good luck, to you and me both.
Thanks for chiming in guys.
I think I'm going to do a processor based on a 55 gallon drum and weld on a cone bottom. Theres a surplus store here and they have a bunch of these dome like shaped pieces of metal. I think that would work pretty good to make a "conish" bottom. I found the cone bottom's online but it's $75 with shipping, when i can go get the dome for under 10.
I checked out your gallery before fabman, I'll check it again and look it over. Theres a post on the forum here with a 55 gallon cone bottom drum, then 2 other drums to wash and dry the fuel, I like how it's set up and it's actually what I was thinking of originally.
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
11-30-2007 11:49 PM
RDC F250 7.3
08-13-2006 11:16 AM
buckshot047
51
10-18-2005 08:52 PM
