351M/400
04-04-2001, 06:44 PM
04-08-2001, 08:06 AM
on
351M/400
I need a C4 bellhousing and or trans from a 77-79 351/400 working or not for my 460
04-08-2001, 11:55 AM
351M/400
Did they even make a C4 with the big block bellhousing bolt pattern?
04-08-2001, 12:16 PM
on
351M/400
the 351M/400 has the same bellhousing bolt pattern as the 429/460
I have a C6 in my car now and its a little big,plus the C4 weighte less.I only need the bellhousing from the 351M/400-C4,but if someone has a trans and bell working or not i would be interested
04-08-2001, 12:45 PM
351M/400
I'm aware the 385 and M series have the same bellhousing bolt pattern which is why I was asking if Ford ever put a C4 behind a big block.
04-08-2001, 12:48 PM
on
351M/400
not that i know of
04-08-2001, 11:13 PM
351M/400
Try ebay I have seen several of them like the one below.
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=569874979
04-16-2001, 10:55 PM
on
351M/400
C/6 IS THE ONLY TRANS FORD EVER PUT BEHIND ANYTHING 351CID OR BIGGER. OTHER THAN FINDING A GOOD FMX TRANNY{AND SOMEONE WHO CAN ACTUALLY BUILD IT RIGHT}YOUR STUCK AS FAR AS AUTO'S GO.I MAY BE WRONG,BUT I'VE NEVER HEARD OF A C/4 WITH A 385 SERIES BOLT PATTERN.
04-17-2001, 12:39 AM
351M/400
[font size="1" color="#FF0000"]LAST EDITED ON 17-Apr-01 AT 01:51 AM (EST)[/font][p]I parted out a 79 F150 with a 351M with a C4 transmission. It's called a High Pressure C4. I'm not sure how long this trans was used or made but, Ford did make such a animal. It will bolt behind a 385 series BB. As far as I know and found, it has never been used behind a 429/460 and does share the same bolt pattern as the 335 series per Tbolt460 statement.
It is now being used in my 71 Mach with a 514 stroker soon to be equipped with a Gear Venders Trans.
Xaviar
96 F-250HD 4x4 460/E4OD 4.10
Banks Power Pack, Banks Trans Command
MSD 8227 Coil, MSD 32199 8.5 Wires, MSD 6A
04-17-2001, 02:10 PM
351M/400
[font size="1" color="#FF0000"]LAST EDITED ON 17-Apr-01 AT 03:10 PM (EST)[/font][p]>I MAY BE WRONG,BUT
>BOLT PATTERN.
Gee that one on eBay must be a figment of our imagination.
04-17-2001, 03:50 PM
on
351M/400
what is so hard to understand,the 351/400 has the 429/460 bellhousing bolt pattern with a C4 trans on it!!.The 351C has the small block pattern.What about the one on ebay!Thats what u need to put the C4 on a 460. 10-4
04-17-2001, 03:53 PM
on
351M/400
the transmission does'nt have the 460 bolt pattern, the bellhousing does
04-17-2001, 10:46 PM
on
351M/400
gee bill, i guess you actually looked at the picture of "THE FLAIR CASE". GOOD GRIEF!
04-18-2001, 02:10 AM
on
351M/400
what transmission was used behind the 351/400? The FMX or C4.Can the bellhousing Be taken off the FMX like the C4 can?
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
