Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
first gen lightning tire pressure
Old 03-12-2008, 06:59 PM
jaceqq's Avatar
jaceqq
jaceqq is offline
Hello, I have a 92 2wd Nite flare side.Going to upgrade to the 17 inch lightning wheels. Just wondering what psi you guys/gals are running on the stock size tires. Thanks for any help Jace
Old 03-15-2008, 06:09 PM
Jason Lewis's Avatar
Jason Lewis
Jason Lewis is offline
On my Gen 1 Wheels I am using Yokohama AVS 275/60 R17 With 40 PSI All Year Around. If i go lower in the psi range like 35 the truck drivies sloppy.
Old 03-16-2008, 12:09 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
On my truck, I run 38psi up front and 35psi for the rear tires. Just experiment with the pressure and you'll find one that works best for you.
Old 03-18-2008, 08:26 PM
jaceqq's Avatar
jaceqq
jaceqq is offline
Thanks guys. I started out at 45 and the ride is a bit ruff. I've started dropping down a few pounds each day. Getting close to the sweet spot. Jace
hotrod96
11-04-2008 04:20 PM
jermdawg
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
05-11-2006 03:31 PM
Explorer_Lightning Wannabe
12-15-2002 08:55 PM
blue2002
07-23-2002 07:16 PM
Lightning Bob
02-13-2001 10:10 AM
Quick Reply: first gen lightning tire pressure
