Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Transmission bolt patterns.
Old 03-10-2008, 03:35 PM
TheTowingCowboy's Avatar
TheTowingCowboy
TheTowingCowboy is offline
We got a Explorer with a A4LD transmission in it, and we have decided we are going to make it 2WD, since the A4LD is shot in it. Okay does a 4R44E bolt up the same as the A4LD? Cause if so we will put one of those in.
Old 03-10-2008, 09:47 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
motors are the same so i would think the transmission bell housings are the same pattern.. what you will need to consider is the front axle. are you just going to remove the half shafts and leave the pumpkin setting in the middle of the truck? the front wheel drive bearing/ hub assembly relys on the axle shaft to be present and the outer axle nut tight to hold the two bearing halfs together. i guess you could cut off the half shaft at the CV joint and stick it back into the hub and tighten the outer nut???
PatrickMcD
Bronco II
03-09-2017 09:03 PM
stfree
01-20-2013 02:08 PM
goose213
11-11-2005 02:08 PM
matthews_56
07-10-2003 06:43 PM
rjcline
Aerostar
06-29-2002 08:51 AM
Quick Reply: Transmission bolt patterns.
