I want to install a transmission temperature gauge
Hi,
Looking for some insight again. I am a new (to me) ex owner. I'll be towing a boat with it and would like to install a tranny temp gauge. It's an '01 xlt v-10 4x4 with the 3:73 gears. Boat is around 6k, shouldn't be much of a challenge, in the future I'll be getting a trailer and I do a bit of light off-roading here in AZ where we have some pretty big hills and high temps.
It does not have a factory gauge. What am I looking at to install an aftermarket gauge? Where will the probe go? I'm assuming there should already be a spot for it? Any suggestions for a good / inexpensive gauge? Any other comments or suggestions?
Thanks
Thanks
Originally Posted by anothersteveg
Hi,
Thanks
Thanks
You need to get
1. Dipricol trans gauge or other brand you like
2. gauge pod holder
and here are some instructions http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
Not sure how much just a trans gauge is...
But here is another possible option that gives you WAY more than just trans temps. It is an OBD2 single gauge pod that tucks nicely at the bottom of the A-Pillar and uses the factory sensor.
Just another option is all...
Good luck,
joe.
https://www.ford-trucks.com/forums/6...ight=aeroforce
And here is a quick picture
Good luck,
joe.
That's perfect, I'm glad I asked. So the truck already has a sensor in the tranny even though I don't have the factory gauge? I know they monitor a lot of things, didn't know about that though.
Got lots of upgrades to put in the EX, will post pictures when I get them all done.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Nick
I monitor the trans temp with my Scan Gauge 2. It displays much more than trans temp and also reads/clears dtcs. I'm happy with it thus far.
I bought mine from www.mgtmotorsports.com and I spent the extra and got the blendmount kit, which works well. I need to buy a longer 14' Ethernet cable though because I routed the cable so it can't be seen.
www.scangauge.com
www.scangauge.com
Originally Posted by weekendwarriorfsw32
So even 01 X should have a trans temp sender. Never knew that. Its ture you do learn somthing new every day.
So I'm still confused. Some say it has the sender, some say it does not. Where is it actually located? I'm thinking I need to get underneath and see if it actually has one. Is it accessible or internal? Any obvious way to see if it's there before I hook up the gauge?
http://www.dfuser.com/Install%20Guid...structions.pdf
Page 5
The factory sender is VERY accurate, the calibration on the gauge in the dash is next to useless. If you use a gauge the reads the OBDII data it will have a very accurate reading.
