Gas Saver? Welder& cutter?
Old 03-02-2008, 08:55 PM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
I was sent this link by a friend.
http://carpoweredwater.blogspot.com/
Old 03-02-2008, 11:26 PM
aurgathor's Avatar
aurgathor
aurgathor is offline
Tell him to fill up with it.
Not sure what's in that link, but I know it's not even worth to open it. Here's one similar thread: https://www.ford-trucks.com/forums/4...r-as-fuel.html
Old 03-08-2008, 03:57 PM
blue beast's Avatar
blue beast
blue beast is offline
H2O powering anything but a hydroelectric generation plant that then charges an
electric car is the only way we will be driving "powered with water" But H2O2 is
a possibility if it wasn't so dangerous at the purity needed to be used as a fuel!!
Yes hydrogen peroxide it is a viable alternative But the majority of the H202 that
is produced is used for spaceflight and that isn't going to change anytime soon.
The H2O2 you have in you medicine cabinet is only 3% and you can see it's reactivity
with contact on just skin. If a higher percentage was used and with a cataqlyst we
could have turbines powered by it by just the liberation of the components, then
take the O2 and the hydrogen and combine that with some fuel (alcohol, kerosene
just about anything) and use it to fuel a internal com bustion engine in a Hybrid
type vehicle basically the turbine spinning a generator to charge up some capacitors
and battery banks then power a electric motor transaxle with the engine as a backup.
libbymabb24
1997 - 2003 F150
08-04-2011 10:54 AM
tomtoc
1983 - 2012 Ranger & B-Series
12-29-2006 03:52 PM
agryphon
11-29-2006 07:22 PM
Young81k
23
07-11-2006 04:13 PM
Quick Reply: Gas Saver? Welder& cutter?
