converting auto windows to manual
Old 03-02-2008, 02:29 PM
Mat J's Avatar
Mat J
Mat J is offline
what all is needed to do this and how hard is it?
iv got auto windows in my 88 250 but they dont work. i can fix them myself, but i would rather have manual windows. my truck is a mud truck and gets wet thats why.
Old 03-02-2008, 03:06 PM
TMF's Avatar
TMF
TMF is offline
I did it when I swapped doors, but I did it the really easy way: new doors were manual, old doors were power. I simply cut the harness and taped off the ends when I removed the old doors. I did notice that the rubber grommet/tube from the a-pillar to the doors is different from trucks w/power windows/locks. The powered versions are bigger.
Old 03-02-2008, 03:17 PM
Mat J's Avatar
Mat J
Mat J is offline
yeah that is cheating i dont want to get new doors.
i could get the parts from a junk yard so it wont be a problem, i just want to have an idea if this is even some what easy or not even worth it.
Old 03-02-2008, 03:21 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
i would fix the power windows.
not real hard or expensive to do.
or gut them out and use seat belt straps to open and close them.
Old 03-02-2008, 03:26 PM
Mat J's Avatar
Mat J
Mat J is offline
yeah i can fix the power windows easy, i just dont really want to have power windows because of what i use my truck for water gets into the motors.
how would i use seat belt straps not that i want to do that its to ghetto for me.
Old 03-02-2008, 03:43 PM
quicklook2's Avatar
quicklook2
not too ghetto for many race cars to use in old drag racers.
search 'ford thunderbolt' and you will see some shots using them.
Old 03-02-2008, 04:05 PM
Mat J's Avatar
Mat J
Mat J is offline
i tried searching couldnt find anything
Old 03-02-2008, 04:07 PM
quicklook2's Avatar
quicklook2
i could not either.
i will try to find a link for you.
Old 03-03-2008, 08:54 AM
chewie1014's Avatar
chewie1014
chewie1014 is offline
I'm thinking a manual crank from a donor vehicle should bolt into your pickup without any problems - though you may have to drill a hole or two. You'll need to remove the motor, which will require you to drill out the rivets. Disconnect the wiring harness. Remove the wiring harness so it's not around to get hung up . Your current window bracket should be usable but you'll need to remove the entire power regulator. Install the manual regulator and hook it up to the window bracket.
You'll need door panels for a manual crank and probably can pull these from the donor vehicle. Don't forget the window crank handles.
Old 03-03-2008, 09:09 AM
stm250's Avatar
stm250
stm250 is offline
I want to do this also I hate all the power crap just more to go wrong I also use mine as a mudder most of the time so thats a great idea -Scot-
Old 03-03-2008, 09:20 AM
Conanski's Avatar
Conanski
Conanski is offline
This isn't hard at all, all the mounting holes are already in the door you just have to drill out the rivets and use bolts and captive nuts or new rivets to mount the manual cranks.
Old 03-03-2008, 10:20 AM
Mat J's Avatar
Mat J
Mat J is offline
thanks guys im going to go for it. iv already had the motors out of the doors so the are bolted in now.
im going to try and get the parts together from a junk yard and try it out.
Old 03-03-2008, 01:08 PM
jas88's Avatar
jas88
jas88 is offline
I've got manual window regulators I took out of my '91 F150 when I converted it to power, I will swap with anyone who wants to send me their power stuff that I can keep for spares.
Old 03-03-2008, 02:47 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
I had no problems swapping a set of 87 manual regulators in to my 89. The regualtors mount in diffrently but the doors I had have both sets of mounting holes.
Old 03-03-2008, 05:38 PM
Mat J's Avatar
Mat J
Mat J is offline
JAS88 send me an email adddisorder AT aim DOT com i am interested in doing a trade, the only thing that i want to keep would be my switches so i dont have holes in the door pannel left open, let me know.
Quick Reply: converting auto windows to manual
