1999+ F250/F350 Front Axle Specs
I've searched for a while trying to find a site that has a bunch of specs on the front axle on the F250's & F350's but have been unsucessful. I would really appreciate a link to a site that has information on the front axles found in those years, ie if they're high pinion or low pinion, how wide they are (WMS) stuff like that.
Thanks for any input.
Its either a D50 or D60 depending on the year and build. Outers are the same on both. inner axle shaft lengths are 15.39" and 37.69". Stub shafts are 9.39"
All ford front axles housings are high pinion reverse-cut gears. Dont know the wms length without measuring it. I have a F450 axle in mine now since I bent the D50 I had. F450-550 axle housings are about 2" wider.
Originally Posted by nierace
So they're all HP, thats what I really wanted to know
Thank you guys !
Thank you guys !
Now I have one, showing you can always learn something new. What is wms? Wheel mounting surface? Just a guess.
burnthelight88
11-18-2020 06:46 PM
daisyman
01-12-2016 02:33 PM
