Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Cmon carb guys...HELP
Old 02-28-2008, 07:53 PM
Blutox's Avatar
Blutox
Blutox is offline
got a 75 F-100 with a re-built 400 and a 2 bbl re-built carb installed about 1 yr ago. Ran great for the few trips I've taken since getting the carb and then it started overflowing.
When I would take the needle out and re-install (It all looked great, no dirt at all) it would run fine for a while, but everytime I was sure it was good to go...overflow again.
Put a new fuel line on it and an aftermarket in-line fuel filter and it still overflowed.
Went ahead and got a re-build kit and replaced the perfect looking needle/seat and gasket. Thought sure that would do it...drove it about 30 miles and it did fine. Next day I cranked it just for the heck of it and........Yep, overflowed again!!!
What now? Fuel pump??? The pump seems to be fine. No noise, no leaks.
I'm out of ideas. Y'all got any??
Bill
Old 02-29-2008, 06:16 AM
3broncocrazy's Avatar
3broncocrazy
3broncocrazy is offline
Bump to the top for help
you might want to post in the carb thred https://www.ford-trucks.com/forums/forum72/
- Ga has been asleep here lately..
Old 03-01-2008, 09:50 PM
old87's Avatar
old87
old87 is offline
if it's old enough to have the old floats may wanna check that- good luck.
Old 03-02-2008, 01:29 AM
Power_Hungry's Avatar
Power_Hungry
Power_Hungry is offline
Former ******
Did the carb kit come with a new float? If not, junk it and get a new one. Also, make sure you have the float height correct or you're in for a world of headaches.
Bill
Old 03-02-2008, 09:07 AM
Blutox's Avatar
Blutox
Blutox is offline
Thanks power Hungry,
Nope, no float with the kit. I guess I can buy it seperately?
Do you know where I can find the specs for a wet check? My kit instructions only had measurments for "dry" float height. It said to refer to my service manual (that I don't have) for "wet" specs.
Also...
Should I sop all the gas out and do a dry measure.
Can ya tell I'm pretty new at this? Haha
Thanks,
B
Old 03-02-2008, 11:12 AM
Power_Hungry
Former ******
If the float is saturated, it's useless. The instructions in the card kit should have had specs for a wet check, but it's a little tricky and I don't recommend it which is probably why they don't include it any more. Taking the air horn off a Motorcraft 2bbl is easy enough and the engine will idle fine with it off. Keeping the fan from blowing stuff everywhere (including in your clean carb) is another matter.
Save yourself the trouble... spend $8.95 for the float and be done with it.
Bill
