camper shell heater mod
My idea is to tee off the block and run the hoses down the passenger side under the cab to quick disconects in the bed. I'm going to bulid a box for the fan and heater core with a handle to remove when i need or want bed space. any ideas or suggestions are welcome and thank you all for your help.
Originally Posted by Big_Al59
If I am understanding this correctly, you would have to have your engine running to get heat in the camper/canopy. Wouldn't a small "indoor safe" propane heater work for you? Something like a Mr Buddy heater?
I would use a set of valves so I could control where my coolant is flowing in case I
just wanted cab heat or just bed heat, either manual or vac controlled valves. A old
street bike radiator or even an a heater plenum out of a small car and leave it together
with the fan and everything enclosed in a plastic plenum(match the sqft heated space)
A remote starter would be a good thing to have and tie it in to a thermostat so when
hit a certain temp it would start up and reheat the system. A small auxillary electric
water pump on a 555 timer circuit to circulate the water every 5 minutes for say 2 min
to get some of the heated and trapped water out of the block and into the bed.
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/egnsea...+115&x=22&y=13
I would put an extra battery in case the water pump sucked down the juice(5amps)
sitting there for a long time, At least a voltmeter in the bed so you know the level.
More than likely not, but it's nothing you couldnt set up. Using a relays or some and/or gates to trigger power to the solenoid for a preset time or using a tach signal to shut off solenoid power. Have it give the ignition power for a preset time to warm it back up, then kill the ignition power. You would just have to make sure that it's always in neutral and the e brake is set.
Originally Posted by chrono4
Sounds like it would work. I would insulate the lines from the outside the best that I could though, maybe run them inside of another larger rubber line. Take some pics if you do it.
4x4 Bart
44
03-07-2014 12:39 PM
