08 Expedition recalls (Brakes-latch-Air bag)
Old 02-21-2008, 04:24 PM
08LTDEL's Avatar
08LTDEL
08LTDEL is offline
Here are the three recalls for the 08 Expeditions. The mushy brake problems do have a fix (I think). See below.
Make : FORD Model : EXPEDITIONYear : 2008
Manufacturer : CONTINENTAL AUTOMOTIVE SYSTEMSMfr's Report Date : DEC
04, 2007
NHTSA CAMPAIGN ID Number : 07E105000 N/A
NHTSA Action Number: N/A
Component: SERVICE BRAKES, AIR:ANTILOCK:CONTROL UNIT/MODULE
Potential Number Of Units Affected : 10481
Summary:
CERTAIN CONTINENTAL AUTOMOTIVE ABS AND ESC CONTROL MODULES SOLD FOR
INSTALLATION ON THE VEHICLES LISTED ABOVE. SOME OF THE HYDRAULIC
VALVES IN THE ESC MODULE WERE BUILT WITH EXTRA CHECK *****.
Consequence:
THE EXTRA CHECK ***** CAN RESTRICT THE FLOW OF BRAKE FLUID THROUGH
THE VALVE AND CAUSE REDUCTION OF BRAKE FORCE.
Remedy:
EACH VEHICLE MANUFACTURER WILL FILE A DEFECT REPORT AND REMEDY PLAN
FOR THEIR VEHICLES WHICH INCLUDED THESE MODULES AS ORIGINAL
EQUIPMENT. VEHICLES WILL BE REPAIRED AT NO COST TO THE OWNER. OWNERS
CAN CONTACT EITHER THEIR VEHICLE MANUFACTURER OR CONTINENTAL
AUTOMOTIVE AT 248-393-5300 FOR FURTHER INFORMATION.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY
ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY:
1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Manufacturer : FORD MOTOR COMPANYMfr's Report Date : NOV 14, 2007
NHTSA CAMPAIGN ID Number : 07V541000 N/A
Component: AIR BAGS:FRONTALRIVER SIDE INFLATOR MODULE
Potential Number Of Units Affected : 45
Summary:
CERTAIN VEHICLES FAIL TO CONFORM TO THE REQUIREMENTS SPECIFIED IN
FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 208, 'OCCUPANT CRASH
PROTECTION.' THE DRIVER AIR BAG MODULE MAY NOT HAVE BEEN PROPERLY
ASSEMBLED.
Consequence:
THIS CONDITION MAY PREVENT THE DRIVER AIR BAG FROM PROPERLY
DEPLOYING AND REDUCE OCCUPANT PROTECTION IN THE EVENT OF A CRASH.
Remedy:
DEALERS WILL REPLACE YOUR DRIVER AIR BAG MODULE FREE OF CHARGE. THE
RECALL BEGAN ON NOVEMBER 20, 2007. OWNERS MAY CONTACT FORD AT
1-800-392-3673.
Notes:
FORD RECALL NO. 07C19. CUSTOMERS MAY ALSO CONTACT THE NATIONAL
HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT
1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
Manufacturer : FORD MOTOR COMPANYMfr's Report Date : FEB 04, 2008
NHTSA CAMPAIGN ID Number : 08V058000 N/A
Component: LATCHES/LOCKS/LINKAGESOORS:LATCH
Potential Number Of Units Affected : 123632
Summary:
FORD IS RECALLING 123,632 MY 2007-2008 EXPEDITION AND LINCOLN
NAVIGATOR VEHICLES. THE DOOR HANDLE HOUSING EMBOSSMENT RETAINING THE
BOTTOM OF THE INTERIOR DOOR HANDLE SPRING ON ALL SIDE DOORS MAY
FRACTURE DURING NORMAL CUSTOMER USAGE. THIS CAN RESULT IN
INSUFFICIENT SPRING FORCE TO RETURN THE HANDLE TO THE FULLY CLOSED
POSITION. THE HANDLE MAY BE LOOSE CAUSING A RATTLE OR NOISE AND THE
HANDLE MAY NOT RETURN TO THE FULLY CLOSED POSITION. THIS CONDITION
MAY ALSO PROVIDE A DELAYED RESISTANCE WHEN ACTUATING THE HANDLE
PRIOR TO OPENING THE DOOR.
Consequence:
IN THE EVENT OF A SIDE IMPACT CRASH, THE INTERIOR DOOR HANDLE MAY
CAUSE THE DOOR LATCH TO OPEN INCREASING THE RISK OF INJURY TO A
VEHICLE OCCUPANT.
Remedy:
DEALERS WILL REPLACE THE INTERIOR HANDLE SPRING ON ALL SIDE DOORS.
THE RECALL IS EXPECTED TO BEGIN DURING FEBRUARY 2008. OWNERS MAY
CONTACT FORD AT 1-800-392-3673.
Notes:
FORD RECALL NO. 08S03. CUSTOMERS MAY ALSO CONTACT THE NATIONAL
Old 02-21-2008, 08:34 PM
IQ9's Avatar
IQ9
IQ9 is offline
THANK YOU SO MUCH!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have been wanting to know what to look for in the mail on my 2008. I just got the door latch.
Old 02-21-2008, 10:02 PM
08LTDEL's Avatar
08LTDEL
08LTDEL is offline
You are welcome!
I will be taking the Ex in to the dealer next week and will report if this fix helps the mushy brakes.
Tri color white/EL Limited-boards-DVD-Nav-roof-20's
Old 02-21-2008, 10:46 PM
IQ9's Avatar
IQ9
IQ9 is offline
I will be watching to see what you find out.
Old 03-03-2008, 01:30 PM
njriderac's Avatar
njriderac
njriderac is offline
Keep in mind... these are not for every 08 expy..
I have a 2008 limited & checked the VIN vs. a dealer and called Ford and had no open recalls on my particular truck. Depends heavily on your mfg date.. i don't recommend calling Ford - they told me 10 times i could do it on the website by entering your VIN.. but i wanted a voice. After the 9th or so time she told me, i figured it might be accurate online also.
Old 03-04-2008, 12:14 AM
IQ9's Avatar
IQ9
IQ9 is offline
Well, I now have the lact recall but nothing else.....yet.
Old 03-04-2008, 06:21 AM
chuck s's Avatar
chuck s
chuck s is offline
The door spring issue was fixed during my tire rotation - oil change scheduled maintenance. Took minutes only.
-- Chuck
Old 03-04-2008, 11:01 AM
berry1234's Avatar
berry1234
berry1234 is offline
-- Chuck
Really? They have to pull all the door panels off.
Old 03-04-2008, 12:11 PM
IQ9's Avatar
IQ9
IQ9 is offline
I hope mine goes as fast as yours did. I need to get the oil change done soon. I just got my case of Royal Purple off EBay so I should be good to go this week.
Old 03-04-2008, 06:07 PM
chuck s's Avatar
chuck s
chuck s is offline
Minutes as in about 30 more than a normal 5,000 mile service takes. No more than 90 total.
There's a kit for the recall. Check that the dealer has the parts.
-- Chuck
Old 03-04-2008, 06:55 PM
berry1234's Avatar
berry1234
I guess a pro can pull a panel in 5 minutes, put the spring in in 1-2. Sounds about right.
Old 03-04-2008, 08:49 PM
IQ9's Avatar
IQ9
IQ9 is offline
I will call to make sure all is well before I show. I have done it the other way and gotten quite the suprise. I will see how long it takes them for mine and report back.
Old 03-08-2008, 12:16 AM
IROC it's Avatar
IROC it
IROC it is offline
Dealer did my door handle while I was in for some basic TLC...
They should automatically check for these things if they're doing their job properly.
Funny thing was... we'd had no trouble, but they replaced the spring any way.
Old 03-09-2008, 01:14 AM
IQ9's Avatar
IQ9
IQ9 is offline
Well, I got the oil changed BUT no springs. Their system showed they had them but none to be found. The guy before me had the same issue we both got oil changes and tire rotations on the house though. I am now waiting for my call that they are in.
Old 03-09-2008, 11:58 PM
SemperFiDevilDog's Avatar
SemperFiDevilDog
SemperFiDevilDog is offline
I need to look into this....Thanks
Quick Reply: 08 Expedition recalls (Brakes-latch-Air bag)
