1976 F350 dually
Since they didn't make a factory F350 dually in 76 (unless is was a flatbed, I think) I would look for the quality of the conversion. Others here will have better specifics to look for..
Good luck on the auction!
Dak
Dak
Its like the first picture (not as fancy) and definitely factory type. The rear is dual wheels. On the inside door panel it has Canadian Trailmobile Corporation, so guess they did the conversion for FORD. I saw the truck this morning and it will need a little work...a few small holes above rocker panels, emergency brake stuck and owner says clutch is not good. I started it and put it in gear but need to raise clutch to very top to engage, so it works but not the way it should. The brakes, wipers, exhaust, lights, horn, window regulators, defroster, guages all seem to work. Its a manual transmission with a 351. I can't tell too much about the suspension but frame looks OK with only a bit of surface rust. Will this truck be money pit or are repairs easy to do?
Dak
Dak
For example all the 1973/79 F350 dually's U-Haul owned, had a box on the back. Other bodies could be stake beds, utility beds, dump beds, etc.
There were no factory F350 Styleside pickups with dual rear wheels till 1980.
cowgirlup11
04-03-2011 12:35 PM
jowilker
06-03-2000 11:48 AM
rob albright
06-09-1999 05:39 AM
