using ATF as fuel
It has been covered in another thread, but what will the ATF cost you? Unless you are going to run new ATF in your truck, you run the risk of messing a few things up. To expand on that, used ATF has metal particulates floating in it that even filtering won't get out. suspended in the fluid like that they become a lot like sand in a sand blaster. Your injectors will definitely need replacing (quicker than normal). Everything that it comes in contact will wear at an accelerated rate...... how quick depends on the volume of matter in the ATF.
The way I see it, your playing Russian roulette if you use the contaminated ATF, you might do just fine, or your truck might fall apart. Not a chance I would take.
