parking brake gets stuck
83 ford ranger notices the parking brake gets stuck my parking brake half *** works feels loose when i press the parking brake. but you kina feel it when its in gauged. what can i do to make it not stuck i have to move the truck forward and back to kinda release it.
I recently changed my rear drum brakes on my 88 ranger, and I started experiencing the same exact thing you are describing. Mine worked fine before I changed the brakes. I haven't tried fixing it yet, cause I busted my front piston lol.
Mine seemed to get a little better the more I used it...
I've noticed the same thing with my ranger. Driver's side pB assembly on the shoe always seemed hard. Finally starting to stick now that's it's cold. I was going to cut that side off and just use the other side till i saw the driver's side is tied to the main cable...
BTW WD40 will not break down rust. it's a lubricant. You need Kroil or PB blaster.
ColdRavioli
03-31-2011 08:04 AM
