code po266
Old 02-17-2008, 05:27 PM
caterpillar702's Avatar
caterpillar702
caterpillar702 is offline
code po266
I have a 1999 f250 sd 166000 mi & it has a code po266 cylinder#2 contribution / balance fault. !!!! does this code mean the injector needs to be replaced;; i had someone with a scaner check it & he said he has changed the valve cover gasket & that fixed the miss;can anyone help!!!!!!!!!!!!!! thank you for any help.does anyone know the mieage for the injectors for replaceing them!!!!!!!!
Old 02-17-2008, 06:29 PM
bkcowboss's Avatar
bkcowboss
bkcowboss is offline
Welcom to FTE, you will find the answer to your problem here, and we should be able to save you money if you can turn a few wrenches.
To better diagnose the problem can you post how the truck is currently running, if it has a miss did it happen immediately in all RPM ranges and idle or does it only happen when accelerating or cold.
there are several different scenarios from dirty and burnt UVC (under valve cover) pins, UVC wiring harneses, injectors (does not always mean they need replaced) as much info that you can provide would be helpful
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
Is the engine running bad? maybe after fixing the valve cover gasket, the connector is good now (which fixed your miss) and the code was never reset ?
Old 02-17-2008, 08:17 PM
caterpillar702
I frist notice the miss at idle; then at take off;;its realy bad at idle;;i ohm out the #2 wires from the injector to the top of valve cover gasket & on the ground i had 3 terminals showing continuity; so i removed the wiring harness & ohm out the harness & it checked ok then with only 1 ground then i plug it to the gasket & it checked ok ; i bought a new harness & put it in & checked it & it checked ok. i started & it acted like it was ok till i throttle it up & back to idle & then it started with the miss again;;;could it be in the gasket!!thanks for the help;; i work for a cat dealer on heavy equitment;; 1st time power stroke
Old 02-18-2008, 08:53 PM
caterpillar702
after new gasket;new wiring harness;still has miss;;the service engine light doenst come on;;on a snap on scaner it shows the code ;; u think i need to try a injector!! thanks for your help.
Old 02-19-2008, 07:14 AM
bkcowboss's Avatar
bkcowboss
did you do a buzz test and a cylinder contribution test? Also did you check the pin on the exterior plug for the main engine harness to see if the plug is burnt or corroded?
Old 02-20-2008, 06:28 AM
caterpillar702
i did do a buss test; & all 8 clicked; i all so looked at the pins on top of gasket; i didnt see any that looked burnt; iam going to swap holes & see if the miss goes to #4. thanks for your help;; it seems like when i start it ;cold that it doesnt miss , untill it warms up. it never turns the service engine light on. it must be mechanical !!!!
Old 03-07-2008, 08:43 PM
caterpillar702
problem solved;;the injector was bad i replaced it back on the road;;thanks for the help
Old 03-08-2008, 11:45 AM
clintbonnie
Good going caterpillar....!!
Joecool1
04-14-2017 08:27 PM
David7.3
23
03-19-2017 04:36 PM
DoesItReallyMatter?
85
04-23-2014 07:32 AM
ltramon45
08-21-2013 02:07 PM
Selkirk
1978 - 1996 Big Bronco
11-08-2008 07:43 AM
Quick Reply: code po266
