534 general specs
Old 02-12-2008, 07:21 PM
jauguston's Avatar
jauguston
jauguston is offline
534 general specs
Hi guys.
I just joined and am trying to help a friend get some general information on a 534 Seamaster marine engine. It would be more than I could hope for to get any information on the marine version but we can hope. Otherwise info on the truck engine would be helpful. I worked on these engines as a mechanic in a Ford dealer in the mid 60's but I don't have any info on them.
The kinds of things like horsepower and maximum rpm would help as well as what it weights. It may go into a 1927 triple cockpit classic runabout that is being restored. The original engine is a huge 6 cylinder and is not repairable.
Any help or leads to information will be greatly appreciated.
Jim
Bellingham,WA
Old 02-13-2008, 09:23 AM
manglass's Avatar
manglass
manglass is offline
Check the post, "534 vs Everyone else." I think there was mention of Seamaster there. You might also check posts by "admiralturbo" I believe he has discussed that engine a few times. Hope you find something, I'm sure that motor has been talked about in this forum before.
Lou
Old 02-13-2008, 01:24 PM
jauguston's Avatar
jauguston
manglass,
I looked at his posts and found some useful informaton. One thing I haven't found yet is what it weights, either the truck version or hopefully the Seamaster version.
Thanks for the help.
Jim
Old 02-13-2008, 02:24 PM
manglass's Avatar
manglass
manglass is offline
I don't know specifically but weight of the truck version is usually said to be about 1,000 lb. Add for the turbocharger, plumbing, and marine exhaust manifolds. Pretty heavy.
Lou
Old 02-13-2008, 02:25 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,584 Likes on 1,292 Posts
1032 lbs.
Scroll through this one:
https://www.ford-trucks.com/forums/2...-owners-2.html
three words to consider:
Four, Six, Tea.
Old 02-13-2008, 03:19 PM
jauguston's Avatar
jauguston
1032
Thanks guys. The reason for considering this engine is we have a low hour one available for zip-zero-nada!!
Jim
Old 04-21-2008, 07:34 PM
northern 7.3's Avatar
northern 7.3
northern 7.3 is offline
Temporarily Deactivated
anything free has got to be good.
Island Time
Washington Chapter
16
12-08-2017 10:28 PM
SuperBerry111
401, 477, & 534 SD Engines
11-03-2013 09:30 PM
OnDaRoad
08-26-2013 05:13 PM
Dark Water
04-30-2011 09:42 PM
bobby60
12-18-2009 06:56 AM
Quick Reply: 534 general specs
