460 Freeze Plug
460 Freeze Plug
[font size="1" color="#FF0000"]LAST EDITED ON 06-Nov-00 AT 10:00 PM (EST)[/font][p]A freeze plug on my 1970 460 has a slow leak. It is the plug that is next to the starter. What is the best way to pull it out? Do I tap in a new one to just the same depth using a socket as the installation tool?
Also, I checked a couple of parts web sites, and they had RUBBER freeze plugs! Why? Wouldn't I want another metal one?
I thought about this a bit more, would brass plugs be the best? If one is leaking, should I really replace all the others on a 30 year old engine with 75k miles, or leave well enough alone if the others are OK?
Thanks, Pete L
Thanks, Pete L
460 Freeze Plug
If it were me I would not use the rubber expanding plugs, because they have a tendancy to pop out. You may have to drop the starter, knock a hole or two in it with a screw-driver and a hammer then stick a pair of channel-locks trough the hole and grab it and yank it out. I'm not sure if they make brass plugs or not. you can use a 1/2" drive extension and/or a socke to install the new one. As for rest of them, I would'nt worry about 'em til they create a problem.
Hope this helps.....john
on
460 Freeze Plug
Metal freeze plugs are always the best way to go, but if your trying to make an "in the truck repair" sometimes a rubber plug is the way to go if you don't have room to hammer in a metal one. I've had two different engines that I've installed rubber plugs and never had one blow out. Just make sure you install them dry...and when you finally pull the engine for a rebuild replace the rubber with metal. Deen
I have a quick question i have replaced all my freeze plugs on my 78 ranger with the 302...and thoose were visible ...now i have an 89 f250 with the 7.5 460 i bielive i have a freeze plug leaking.. i cant see for sure if it is one but are there plugs behind the motor mount??? ..o yeah how many dose this block have i have been told it will vary sometimes????
merc460
11-08-2002 10:09 AM
dave460
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
08-04-2001 09:14 AM
chilly460
07-11-2000 11:32 PM
