Reverse tilt hood - 53-56
Could someone with the MMB reverse tilt hood assy on their 53-56 F100 post a couple of close up pictures of the inside of the hood in the area where the stock hinges used to bolt up?
(This would hlp me with yet another custom touch that I'm working on.)
I'd be beholdin to ya!
Thanks,
Thanks,
I believe MMB stands for "Much More Better" - it's the kit made by CPP and sold by Mid-Fifty and Hot Rods Classic Truck Parts.
I've ordered the kit but won't have it for at least a few weeks. I need to understand where the rollers bolt to in the general area of the old hinge mounting area for something else I'm doing to the hood.
If anyone can supply appropriate photos - either post them here or in your gallery or email them to me at the_fergusons at sympatico.ca
Thanks,
Thanks,
The roller monuts into the lower bolt hole as I understand it. I have the kit still in box, but I did read the instructions and it goes into the lower threaded hole so that it can ride the "rollercoaster" guide as the hood closes in the rear. I have no photos, only what the instructions had in them. Heres the link to the magazine article on the install of the CPP kit. It might help you http://www.classictrucks.com/tech/04...kit/index.html
Jon
Jon
I have just installed one of these kits on my truck and I want to give you feedback on my experience.
1- Tape off all points where the hood meets the cowl and front fenders (at the rear). Even after assembly, you will have some shimming and adjusting to do. Be super careful.
2- Get someone to help lift and hold the hood. You will sctrach something by yourself.
3- Get ready for adjusting.
4- You may have to shim or tweak the u-crossmember(what the hood pivots on) a little to keep it off your top radiator valance at least I had to.
5- The kit is easy to install and has a lot of adjustments, I tried to do it mostly by myself and was in a hurry to get the truck to paint. I don't why, its been five years since I started. I guess waiting a few more hours wouldn't hurt.
Good luck and you will be happy with your purchase.
Sorry one more idea, since I am using a fiberglass cab, i could not use the OEM cowl welting that goes between the rear of the hood and cowl. We tried a piece of 3/8" vacum hose slit down the center and glued to the rear lip of the hood worked / looked great. The truck is black so it kinda reminds you of how the fender rubber looks from the outside. I will post some pics after we do some buffing.
John,
Thanks for the tips relative to the adjustable braces you made as well as additional photos of the original rear hinge mount area.
I'll definitvely copy those as well as the pin idea to keep the hood open. I'll likely use one of those pins that has the spring loaded ball on the side near the end then I can simply drill a similar hole on the verticle square tube that abutts the hinge, to store the pin when not in use....
My kit hasn't arrived yet. It's part of a LARGE order I just placed with hot Rod's Classic Truck Parts. Don't expect it to arive for several weeks. I needed to understand what the reverse tilt assy did to the original hinge mount area on the rear of the hood for an additional mod I am working on for the hood.
However, all these tips and suggestions from all of you, relative to the mounting of the reverse tilt kit are greatly appreciated.
Thanks,
Thanks,
Jag Red 54 , When this thread1st started..your struts were the 1st thing that came to mind.
Ferguson777,this mod is one you may want to keep in your tool-kit of ideas.
I might still have to re-think my 'problem-hood' ,maybe consider what you guys have done..please keep us posted ...with done PICS ...Thanks!
Thanks Paul.
Received 4,130 Likes
on
John
