Is it normal for a 10 year old block heater to trip a GFCI outlet that is on the same ciruct as many others within 6 sec of pluging in when it is -15F.
Yes. Find a plug all by itself for it. Don't run an extension cord if possible. If you must, run a heavy and as short as possible one. If it still trips then it is probably shorted and needs replacing.
I run a 12 amp pump regularlly from a GFCI outside, works fine.
I've had cords that had just a bit of water in them trip GFCIs. I would first try another cord, and if it still trips, then the cord going to the block heater on he truck is probably shot.
Had a GFI in my kitchen with nothing pluged in. Wouldn't reset. Finally pushed REAL hard on the reset button and it reset and then stuff replugged and then all worked fine - FWIW
