Mid-West Region Illinois, Indiana,Iowa, Kansas, Michigan, Minnesota, Missouri, Nebraska, North Dakota, Ohio, South Dakota, and Wisconsin.
1978 ford 460
Old 01-31-2008, 03:22 PM
markbo_43764's Avatar
markbo_43764
markbo_43764 is offline
Lightbulb 1978 ford 460
I have a 460 that came out of a 78 camper special it had a auto tranny in it and I want to put it in my 77 highboy and i dont know what flywheel to put in it is it an internaly ballanced or externally ballanced motor?
Old 03-02-2008, 04:00 PM
385seriesHemi's Avatar
385seriesHemi
385seriesHemi is offline
It should be a internally balanced engine if its the stock '78 460. 1979 is when Ford externally balanced the 460s which were 1979 to 1996 -'97.
Old 03-03-2008, 07:04 PM
markbo_43764
78 460
thank you verry appreciated!
Old 03-03-2008, 07:16 PM
385seriesHemi
Yeah, one way you can determine if its external or internal is the weight on the front of the crankshaft behind the harmonic balancer. There should be a Hatchet shaped weight for externally balanced 460.
Old 09-15-2013, 11:55 AM
zedrick1313's Avatar
zedrick1313
zedrick1313 is offline
there is another way to tell if it is internally balanced. look for numbers on the crankshaft. 2ya , 2yab, 2yabc. those are internal external numbers are 3ya , 3yab, 3yabc.
bullnose1985
Engine Swaps
05-12-2014 11:53 AM
JRS2
04-15-2014 08:57 PM
fox3698
06-20-2011 05:40 PM
jetblack06
02-12-2010 07:42 AM
FAL
12-19-2001 06:15 AM
Quick Reply: 1978 ford 460
