Heater not working...
Check to see if the blend door is broken. http://www.blenddoorfix.netfirms.com/
Also seach on this site for heater problems.
if the temp gauge read normal check both heater hoses where they go into the firewall if both hot poss blend door problem if one hot one cold poss has air lock, dirty heater core and water not passing through two type blend door problem on these unit one the electroinc accuator brakes ( gear inside strips) two the blend where the actuator mounts brakes apart good luck
wrd0225
09-30-2014 10:53 PM
GormGorm
10-22-2011 08:04 PM
rooboy
06-29-2008 12:34 AM
