Question on water separator/fuel filter on PSD 2008
Does anyone know if the driver-side rail mounted water separator/fuel filter is heated? Could I have a blown fuse or something? Mine keeps waxing up even with tons of fuel conditioners and after replacing the filter. Still no luck at cold temperatures (as around 0 degrees).
The symptom is: The truck will start real well, but when power is needed, it gets fuel-starved and dies. No problem when warm temperatures.
One other item: My truck was built in January 2007 - among the first 08 models Ford built. I got a $1000 rebate check from Ford as a "thank you for purchasing one of the first" - kinda scary. I have been only once in a Ford shop for a regular oil change/service. I am sure they did not put any updates (at least nothing was stated on the bill to that effect). Aside from the possible excessive exhaust heat issue are there any important updates to consider? If so, is it possible that one or the other may contribute to the problems I am having?
If your fuel gelled your filter on the frame might be crushed from the pump still trying to pump the fuel. Just a thought. There is 2 reflashes that came out after your truck date, you might still have the fire starter flash if so i would get the new one. Dont think that it would cause this prob. I also have a job 1 truck.
SeminoleSlim
25
07-15-2008 10:32 PM
