Iowa Chapter Join Chapter, Leader:
engine heater
Old 01-23-2008, 10:15 AM
jkbeegs's Avatar
jkbeegs
jkbeegs is offline
engine heater
Living in Iowa can you leave your engine heater on for a long period of time on a 2006 6.0 liter diesel engine?
Old 01-23-2008, 12:04 PM
67nukeford's Avatar
67nukeford
67nukeford is offline
I've had mine on since Sunday! I don't think it's a big deal when it's this cold.
Old 01-24-2008, 06:43 AM
fellro86's Avatar
fellro86
fellro86 is offline
Do it all the time with trucks, tractors, the only thing it affects is the power bill, and really, it doesn't hit that too bad, something like 15 cents a day to be plugged in.
Old 01-24-2008, 05:00 PM
428HIGHBOY's Avatar
428HIGHBOY
428HIGHBOY is offline
Only 15 cents? How many watts?
Old 01-24-2008, 05:39 PM
fellro86's Avatar
fellro86
fellro86 is offline
That was a friend telling me what it cost to keep their semi plugged in.
Old 01-24-2008, 09:03 PM
fellro86's Avatar
fellro86
fellro86 is offline
I just remembered a little test I did a while back, had my dad's 84 plugged in, and watched the meter. By the numbers given on that, it was on track to cost about $30 a month if it were plugged in 24/7.I read the meter at the same time 24 hours apart, and our power is about 10 cents a kilowatt/hour if I remember correctly.
Old 01-24-2008, 09:14 PM
428HIGHBOY's Avatar
428HIGHBOY
24 hours x 30 days =720 hours
500 watts / 1000 (kilo) = .5 kilowatt
720 hrs x .5 kw = 360 kilowatt hours
10 cents x 360 kwh = $36
Old 01-26-2008, 08:50 AM
beaners1's Avatar
beaners1
beaners1 is offline
They make little meters to check electrical usage, just plug it in then plug in whatever, tells you how much it uses. Bought mine for $45 and I found out I needed a new deep freeze pretty badly. Kinda nice to know what uses what.
Old 01-26-2008, 06:11 PM
428HIGHBOY's Avatar
428HIGHBOY
Ohms law works too. E=I X R
Old 01-27-2008, 06:50 AM
fellro86's Avatar
fellro86
fellro86 is offline
Ohms is nice for estimates, but without knowing the actual resistance and current, it is an educated guess. Ratings don't guarantee usage. I do know what themeter said for usage, so that's why I went that way. (Not to mention, forgot to try figuring it by Ohm's law...)
buckmasters
6.7L Power Stroke Diesel
10-30-2011 09:05 AM
iowa 7.3
04-26-2011 11:13 AM
danonbar
1999 to 2016 Super Duty
01-22-2005 10:11 PM
F150y2k
08-06-2003 10:24 PM
Quick Reply: engine heater
