97 F150 Door jamb switch for interior lights-Where is it?
Yep, spraying them with electronic/brake cleaner, repeating with WD40/Deep Creep/etc and slamming the heck out of the door a few times generally cures the problem. But since you asked, here's the location of the switch.
1- Interior Lamp Switch
2- Door Ajar Warning Switch
I just sprayed the heck out of the latch with brake clean and did the same with a good penetrant and slammed the door a few times quite hard and still it does not work. Are there any other quick things I can try or is there something wrong in the switch itself. If I have to live with it as as it is not a big deal. Just wanted to rule out all the easy fixes first. Thanks again
Can you just replace that switch or is it built into the latch? i dont know i've never heard of it going completely out. You shouldn't use brakleen on the latch. It'll eat your paint, eat the insulation off your wires, and wash the grease out of your latch. You might unbolt the latch and pull it out and see if the part is replaceable or if you just have to buy a new latch. I'd go to the salvage yard on that one.
It just depends on what one chooses to buy/use.
FYI:
CRC 05152 Brakleen® Brake Parts Cleaner, SCAQMD #1171 Compliant,
K&W (by CRC) 401424 Professional Strength Brake Cleaner Non-Chlorinated,
are both plastic,and concrete,safe.
Quoted from CRC Industries site:
"ABS, disc, drum, all brake systems, backing plates, brake cylinders, brake drums, brake linings, brake pad contact points, brake parts, brake shoes, brakes (mechanical), clutch discs, concrete, cylinders, discs, general degreasing & oil removal.
Plastic Safe Yes"
FYI:
Plastic Safe Yes"
