1978 F350 with 460 Ignition Timing and Idle RPM
Old 01-18-2008, 10:46 PM
malamute552000's Avatar
malamute552000
malamute552000 is offline
I have a 1978 F350 Ranger XLT, 2WD, with a 460, and the 4 barrel holley carb. The emissions control label is long gone.
I'm trying to find the specs for Ignition Timing and Idle RPM. Web searches haven't turned up any useful information.
Do any of you have this info? Thanks in advance.
Old 01-19-2008, 12:03 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Welcome to the site
I can help you.
Your Calibration code for that engine is
8-97-R0
Go to this page and Scroll down to the 2nd last row of specs to find yours
http://www.clubfte.com/users/mil1ion...e-upSpecs.html
Bonus for you:
This page shows your emissions hose routing
http://i69.photobucket.com/albums/i7...97-R0nonac.jpg
Old 01-19-2008, 10:32 AM
malamute552000
Dennis,
Thanks for the info, that is a lifesaver. I should have put this in the earlier question, but do you know if the vacuum hose is to be removed from the distributor vacuum advance when setting the timing. Some info I did find implied that sometimes you remove it, and sometimes you don't.
Thanks again.
Dave
Old 01-19-2008, 01:02 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
No, it is to remain hooked up and make sure the engine is at normal operating temp as well.
Old 02-22-2008, 07:25 PM
kermit's Avatar
kermit
kermit is offline
Sorry to bump this thread from the dead, but didnt want to start another one. Dennis, is that chart you referenced applicable to a 73 f250 w/ a 460 also? Somehow I ended up setting the timing at about 9-10 with the vacuum advance disconnected from the dist and plugged, and the truck has a terrible time starting up. Got the info from here (this site), but dont remember how long ago or from whom ( I have been on 2 cruises back to back and am getting ready for another one, and just havent been around much.)
Thanks,
jamie
Old 02-22-2008, 07:32 PM
masterbeavis's Avatar
masterbeavis
masterbeavis is offline
Try retarding the timing back to 4* or so, see if that helps. Also, is your truck points or electronic ignition? I think the 460 that year was the first to get the electronic ignition.
If you copy the link Dennis posted, and remove the file name, that will show you the listing of all of the items he has uploaded. You might find what you need there, or at his FTE site http://mil1ion.clubfte.com/FordRelatedLinks.html
Old 02-22-2008, 07:55 PM
kermit's Avatar
kermit
kermit is offline
its got new points in it, no electronic ignition. so 4* would be ok and not tear anything up? I have to tow a trans am tomorrow with this truck.
Old 02-22-2008, 08:14 PM
kermit's Avatar
kermit
kermit is offline
I set it to 4* and it starts ok now, but I am worried I have neutered it as far as power is concerned. Is this valid?
Old 02-22-2008, 09:58 PM
masterbeavis
Drive it and see. If you don't like it, keep bumping it up till you are happy with the power, and it starts easy. 4* is where some engines were supposed to be from the factory. The heavier duty, the lower the timing is it seems like.
1978crewcab
04-12-2016 12:05 PM
1978crewcab
04-07-2016 06:03 AM
TTsam
08-31-2015 04:48 AM
lasthighboy
Performance & General Engine Building
09-26-2010 11:37 PM
Craigwell
01-05-2010 01:35 PM
Quick Reply: 1978 F350 with 460 Ignition Timing and Idle RPM
