North Carolina Chapter Join Chapter, Leader:Benztechnc
Is Turbo Back - No CAT OK?
Old 01-18-2008, 05:56 AM
OneTon4Fun's Avatar
OneTon4Fun
OneTon4Fun is offline
I am concidering to buy the turbo back MBRP exahst system, I was not aware that diesel engins used a cat. converter. (I am new to F350s) Will North Carolina instections look for my catylitic converter? If I buy the exhast system with no CAT will it pass inspection?
I could but the CAT version and run the CAT delete, but I won't bother if NC state inspections will overlook the exhast.
OneTon4Fun
Old 01-18-2008, 08:59 AM
MAKO314's Avatar
MAKO314
MAKO314 is offline
I have a straight system with stacks and have never had any problems, but my truck didn't have a cat to start with. Oh btw it's a tricked out built to hell 2000 powerstroke.
Old 01-18-2008, 11:08 AM
Joshua0606's Avatar
Joshua0606
Joshua0606 is offline
OneTon4Fun
What year model is you truck?
Old 01-18-2008, 07:54 PM
OneTon4Fun's Avatar
OneTon4Fun
I have a 2003 F350 6.0
Old 01-18-2008, 08:13 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
you will have to have it if you have a ********* inspector, but alot of guys just cut them off and chance it. there is a cat delete pipe that is made for your truck that can be installed and taken back out with bolts.this way you can replace the cat when needed.
Old 01-18-2008, 08:16 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
I believe the 2008 model diesels are the only ones required to run with catalitic converters. I'm sure your 2003 doesn't need it. Did it even have one on it from the factory?
Old 01-18-2008, 08:22 PM
CampSpringsJohn
Oh, in response to your question, Is turbo back without a cat OK? Yes. Some guys run them with no muffler too. It is legal, at least in Ky. A straight piped diesel isn't as loud as some performance exhausts on gas engines. They do sound good too. Just try and be sensible and not pi#$ off your neighbors late at night, unless of course they deserve it.
Old 01-18-2008, 08:31 PM
OneTon4Fun's Avatar
OneTon4Fun
You know, I really don't know if there is a CAT on my truck. I just see alot of talk about CATS when look at exhaust systems. I am surprised that a diesel engin uses a CAT coverter. Knowing my luck, I have the CAT. I will likely get the MBRP Cool dulas with the CAT and use the CAT delete pipe.
OneTon4Fun
Old 01-23-2008, 07:59 AM
BW68's Avatar
BW68
BW68 is offline
I have a '02 F250 7.3. It did not come factory with a cat. I had a turbo back MBRP installed and absouluty love it! I may be wrong but I think Ford started putting cats on diesels in '03 (I think). My service guy at Hilbish Ford told me if my truck did not come with a cat on it from the factory then I was good on the vehicle inspection. I just need a safety not emission inspection.
Old 01-23-2008, 11:50 AM
OneTon4Fun's Avatar
OneTon4Fun
It looks like in the state of North Carolina I will need to have a CAT if my truck came with one. I may have to get the exhaust system with the CAT and run the CAT delete pipe after I get it inspected.
Old 01-23-2008, 03:43 PM
dixiemudder04's Avatar
dixiemudder04
dixiemudder04 is offline
since we are on the subject of diesels. was following one this afternoon after work and he had something going on. The smoke was white as paper, looked to me like he needed some oil. I dont know what exhaust he had but it didnt sound good IMO. I have a 351 with some 1 chambers that sound awsome. I dunno what 1 chambers would sound like on a diesel. Do diesels have an 02 sensor?? I know my gas motor does. And i think it is behind the cat.
Old 01-23-2008, 04:04 PM
CampSpringsJohn
The older diesels don't have O2 sensors. My 97 and the 02 don't have them. I don't know about the new ones. As for gas engines, the O2 sensor should be located in the exhaust pipe between the exhaust manifold and the catalytic converter.
OneTon4Fun
1999 to 2016 Super Duty
16
02-02-2009 09:14 PM
OneTon4Fun
04-04-2008 10:02 AM
OneTon4Fun
02-22-2008 11:16 AM
Truckin4life
Exhaust Systems
13
02-12-2008 09:09 PM
dhelm72
05-05-2005 12:05 PM
Quick Reply: Is Turbo Back - No CAT OK?
