K&N Air filter?
I used to be a huge beliver in K and N. While I think the filter itself is build well and they have their place in cold air intakes, etc. I think that you have to have the perfect oil content in the filter to get a good balance between airflow and filtration. Too much oil, restricted airflow, dirty MAF sensor, etc. Not enough oil, great airflow, not great filtration.
I am sticking with paper for now. Prices are high, but they should come down.
Oh, and on the two trucks I had KandN filters on, i noticed no increase in anything.
i have the drop in K&N and have noticed better throttle response slightly. Plus it was $30 and the paper ones are close to $20 and are not readily available near me except at the dealership.
I have used K&N type filters in my last 3 cars/trucks and have never had an issue, and I usually keep my trucks to at least 100K.
Personally i wish someone would come out with a cold air intake so i can remove the crappy stock piping. Has anyone taken it off and looked at how restrictive it is. It is unbelievable.
Originally Posted by khadma
KEEP THE PAPER FILTER, REPLACE OFTEN.
You will find little gains in all aspects.
KEEP PAPER FILTER, A tuner will problably serve you better.
You say to keep the paper filter and add a tuner, tuners void the warranty alot quicker than any suspension changes.
Plus there are no tuners available yet for the 07 expedition, I have already checked, plus if you do get a tuner you will need more air flow than that paper filter will ever give you.
