1967 ranchero
Old 01-13-2008, 10:57 PM
customcab66's Avatar
customcab66
customcab66 is offline
1967 ranchero
Is there anyone else out there building a 1967 fairlane ranchero?
Old 02-01-2008, 08:19 PM
1ton460bronco's Avatar
1ton460bronco
1ton460bronco is offline
we built one a few years ago and my dad drives it everyday outside of the winter
Old 02-01-2008, 08:47 PM
ford_boy_1996's Avatar
ford_boy_1996
ford_boy_1996 is offline
yeah I built one last year
Old 02-05-2008, 12:14 PM
tfowler306's Avatar
tfowler306
tfowler306 is offline
My little brother has one he has been working on for about 4 years now... off and on..
Old 12-17-2008, 03:06 PM
hitower4's Avatar
hitower4
hitower4 is offline
I'm building a 66, same basic body but a falcon front end.
It now has a 5.0, 5 speed,sway bars front and back, flowmaster 2 1/2" exhaust, Headman header,Eldelbrock 600 carb and performer manifold, 3.25 gears.On the Hot Rod Power Tour last the car averaged over 20 mpg and over 25 mpg on the hiway. Have fun building and driving your car.
Old 04-19-2010, 10:17 AM
flibo1967's Avatar
flibo1967
flibo1967 is offline
yes i am ,i just bought it out of bradenton fla. im doing the front end first all suspension parts, then the steering box, then on to the rear end,then the interior ,then the 289 4v and t-10 4 speed, dave
Old 04-21-2010, 08:02 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by flibo1967
yes i am, i just bought it out of bradenton fla. im doing the front end first all suspension parts, then the steering box, then on to the rear end.
then the interior, then the 289 4v and t-10 4 speed, dave
Welcome to FTE
No Borg Warner T-10's in Fairlanes after 1965. As original, it would have had a Ford 4 speed top loader.
btw: The correct way is: Mechanical work first, paint/body work second, interior last.
If you restore it the way you've planned, the new interior could get greasy...or worse.
Old 04-21-2010, 11:17 AM
flibo1967's Avatar
flibo1967
well the body is done and painted, interior is probably 90 % done, the car came with a three speed from the factory,the guy i bought it from installed the bw t-10, im not building it to resale or anything like that, im building to go 1/4 mile at a time, it should b a fun project. im probalby 6-10 months away from my goal, then when im done with it ,who knows ill probably build something else, thanks for the info though, dave
Old 07-11-2012, 01:54 AM
kenk71121's Avatar
kenk71121
kenk71121 is offline
67 Fairlane Ranchero 500XL Rear Suspension
Hi FTE,
I just picked up a 67 Fairlane Ranchero 500XL 390/C6. I am going through the entire vehicle. Started & finished the front end brakes & suspension. Im now beginning the rear suspension. I cannot see where you access the upper rear shock mounts . Please dont tell me there is an access panel in the bed. Previous owner had bed Rhino Lined and i'm sure it is not easy stuff to remove;.
Any and all assistance is greatly appreciated.
Thanks,
Ken
Old 07-11-2012, 02:44 AM
NumberDummy
Shock mounts to bracket below spring pack, then thru hole in crossmember. There's no upper shock bracket. Above the hole, just bushings, nuts and washers.
Shown here: 1965/72 Ford Passenger Car Parts Catalog / Illustration Section 54 / Page 4.
This catalog is available on a CD from hipoparts.com
Old 07-11-2012, 03:15 AM
kenk71121's Avatar
kenk71121
Thanks Number Dummy, But how do I get above the hole to put on the bushing/washer/nut??
Old 09-11-2012, 12:18 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,451 Likes on 1,398 Posts
Originally Posted by kenk71121
Hi FTE,
Thanks,
Ken
Unfortunately for you, there is a large access panel in the floor of the bed that accesses the top of the shock absorbers.
63shortbed
06-28-2016 04:26 PM
JoeO
02-12-2016 07:38 AM
MIKES 68 F100
36
03-25-2014 08:13 PM
Cantaloupes
02-28-2014 10:06 AM
Ranchero Stephen
06-30-2012 04:57 AM
Quick Reply: 1967 ranchero
