Brite Box with HID
All of the HID kits offered at www.dabears2k.com are 3x or 6x (35w or 55w) brighter than stock headlights and yet burn cooler than stock headlights.
Our HID kits are guaranteed to not melt the headlight lens.
http://www.dabears2k.com
if you run the wiring harness that is optional with my 55w kit, you will be fine. let me know if you have other questions.
Don't forget, ordering from Dabears2k.com, if we reach 5 orders, everyone gets $5 off
https://www.ford-trucks.com/forums/6...31-2008-a.html
Originally Posted by 4DPLAY
so a guy could run highs and lows with 55watt hids at the same time and should be ok?
Standard bulbs have 2 filaments. Normally one is on for high and one is on for low. The bright box runs both filaments on high, giving you more light.
With HID hi/lo's, there is only one bulb and there is no filament. Hi/lo beam is achieved by mechanically moving the bulb. Since the bulb can't be in two places at once, it can't run high and low at the same time.
Originally Posted by dchamberlain
The way hi/lo HID's work, you won't get any advantage with the bright box and will just be wasting money with it.
You will get better performance by going with an HID kit on standard headlights than going to a brightbox and running halogens.
Like I said, the HID kit will not melt the housing and will give you up to 6x as much light as stock halogens.
landscaper62
1999 to 2016 Super Duty
19
05-11-2019 03:11 PM
bhalemail
18
02-11-2019 06:43 PM
DawnPatrol
11-20-2015 10:34 PM
mechelement
21
01-05-2011 07:51 AM
