reprogramming keyless door combination 2002 ford expedition
No owner's manual?? Do you know the factory code for the keypad?? If not, look for a large white label on a module under the dashboard slightly above the brake pedal; the five digits on that label are your factory code. I can walk you thru the process to re-program once you have the five digit factory code. Step 1: punch-in the factory code. Step 2: Punch the 1/2 pad within 5 seconds. Step 3: Enter your new five-digit code (each digit within 5 seconds). When the keypad illumination goes off, you're done. That's all there is to it!!! Let me know if that works for you.
reprogramming keyless entry door combination
Thank you so much. I tried it and it didn't work, but it could be an electrical problem. I also have no inside lights when the car door opens and when I hit unlock at night none of the inside lights come on. Someone installed a cd player and I think they crossed wires some place that has caused some electrical things. I don't know whether to try to repair it without causing a more serious electrical problem, so at this point, I have left it alone. I was able to program the fob to open the doors, but have already locked myself out once with both fobs in the car. (Brilliant, right?) Anyway, I would love to be able to use the luxury of the door combination. I do appreciate your help. Also, maybe I used the wrong number. There are quite a lot of different letter and number sequence on the sticker. Only one was 5 digits in a row, so I used it. I will keep trying. Thanks again. MCJ
ChrisAdams
2004 - 2008 F150
09-02-2005 11:37 AM
Innova
15
06-23-2005 02:09 AM
pmaldon988
07-15-2003 12:45 AM
2001, 2002, code, combination, combinations, door, expedition, f150, find, ford, keyless, keypad, lock, reprogram, reprogramming, taurus
