anyone know this process?
I have been looking for a cheap kit to make make biodiesel fuel and found a cheap one. I ordered a small start kit before i go all out. You get a barrel a few filters and a pump for not a bad deal. But the recipes are so different then what i have seen any where or heard. The recipe is some thing like mixing 10% kerosene and 5% unleaded gasoline (they say to lower the flash point) and fuel caytalyst bonder which which they sell. the kit is made by bio basics. anyone know anything then or the recipe if its good or not?
There are a few guys doing fuel blending on here. (which is what that is, except they charge you to buy their product, which you can purchase from your local hardware store separately for not much.) You may want to look up some guys who are doing fuel blending to get their formulas and specific things to look at when you chose to go that route.
good luck
good luck
Thanks for the replys. i added up the cost it would be about 60 cents a gallon to make and takes only 5 minutes i have 2 recipes now one for winter and one for summer. one thing i was told besure to filter well and no water. if anyone knows about negative things with this type of blend let me know. thanks
If you still want to try it, save lot's of $$$$$$ for a new engine!
you made me more nervous, what type of set up are you running? i already have a 60 gallon hot water heater. any plans ?
Originally Posted by fabmandelux
Here ya go: https://www.ford-trucks.com/forums/4...=Diesel+Secret
thats what iam thinking about doing now, i dont know much. but i know you have to mix lye and methenol, and remove the glycrine. but that is it. i dont know where to get the chemicals or the plans of converting a hot what heater. im slowily learning here
Originally Posted by bwguardian
If you already have a 60 gallon water heater, why not just produce bio diesel? It is really not all that difficult...I have been doing it for a couple of years now.
Try this site FIRST! http://www.biodieselcommunity.org It will teach you all you need to start. I use a different approach than an "appleseed" style processor, but the end result is quite similar. Try reading some of the previous posts in this forum.
What style processor/reactor are you utilizing?
