Will this work??
Will this work??
I have a Vormax currently filtering my diesel fuel- I bought it a while back when I tried to piece together a home made conversion because of lack of funds. I also tied the two "test" ports on my heads together (cackle cure) with a tee in the middle so I could plumb my wvo in through that with a minumal purge time. Could I purchase a FASS 8A pump, run a return loop, and for heat use my Vormax (take off the diesel line) and put a vegitherm before the tee? And if this works, would the vegitherm be better in the fuel loop, or between the loop and the pump?
mongo75
Bio-diesel, Propane & Alternative Diesel Engine Fuels
10-26-2010 10:59 PM
mongo75
06-15-2007 01:25 AM
mongo75
19
03-17-2007 09:53 PM
leskwvo
12-29-2006 08:27 AM
SMACUSTOMS
11-29-2005 11:58 PM
