300 inline-6 firing order????
Old 06-02-2001, 12:52 PM
brodie's Avatar
brodie
brodie is offline
I cannot find the firing order for my 84 ford bronco 4x4. I rescently changed the cam/lifters, put an offenhuaser intake and holley 4160 carb on her. I got every thing together except the the dist and plug wires. I can't find anything anywhere and then I found this site. Thank-god.
Also, if anyone could give me a wiring diagram or tell me how to wire together the stock dist/coil/ignition system. Appearantly there are 20 or so wires hanging around in there that I don't need or have any idea what they go to. Remember that I changed my intake and carb. I no longer have all of that emissions stuff to worry about.
Other things Ive done to the ole girl: Z-gate shifter, fuel cell, 2800 stall conv, 9" rear-end, 7" of ttl lift, 38.5 supper swamper boggers, pace setter headers, tranny cooler, and I have a mallory dist and Hi-Fire ignition for later, but first I gotta get her running.
Old 06-02-2001, 09:42 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
Can't help you with the wiring, but I do know the firing order:
1-5-3-6-2-4.
Old 06-11-2001, 09:34 AM
Motorcraftsman's Avatar
Motorcraftsman
Motorcraftsman is offline
[font size="1" color="#FF0000"]LAST EDITED ON 11-Jun-01 AT 10:37 AM (EST)[/font][p]i know them numbers by heart 153624 clockwise rotation.
alsoyou said you had twenty or so wires on that ignition system, well im assuming its the tfi system, is it?
if i was you id switch to a simple system such as points, or duraspark 2, clifford has malory distributors for the 300 as well.
John M Floyd
Old 06-12-2001, 10:48 PM
brodie's Avatar
brodie
brodie is offline
got the mallory hi-fire IV and mallory dist. Thanks for the info and I've got her all wired up and running. Just got to tune her and start racing.
Old 06-12-2001, 11:01 PM
brodie's Avatar
brodie
brodie is offline
Old 03-24-2008, 07:56 PM
diolade2002's Avatar
diolade2002
diolade2002 is offline
i need the firing order for an 81 ford 100 pickup. inline 6. the 300.
where should i start on the distributor cap. . any info would be be greatly appreciated.
thanks man
Old 03-24-2008, 09:47 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Welcome to the site. If you scroll up you will see someone has posted it, it is:
1 5 3 6 2 4
Rotor turns clockwise. To find your number 1, there should be a "1" marked on the cap. If not, just trace where #1 is on the old cap before you take any of the old wires off.
Old 12-03-2012, 09:48 AM
Ryan12's Avatar
Ryan12
Ryan12 is offline
Are ford and GM the same as to the location of the number 1 cylinder??
Old 12-03-2012, 11:37 AM
6978sghfbjklgdfsjhkl's Avatar
6978sghfbjklgdfsjhkl is offline
Don't 4 get
1 5 3 6 2 4
unless you remove the distributor..replacing the OLD #1 in the same position on the new cap is what u must do irregardless of where the "1" is stamped on the cap.
Old 12-03-2012, 11:51 AM
Ryan12's Avatar
Ryan12
Ryan12 is offline
My question is concerning the location of the #1 cylinder on a ford engine compared to GM engine. Not the location of the #1 cylinder on the distributor cap.
Old 12-03-2012, 12:21 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
I don't understand what you're trying to say; your sentence is constructed in such a way that makes it difficult to read. My previous post is almost five years old; it is by chance I noticed that you were responding to it. The thread itself is over 11 years old.
I don't know, you're asking questions about a GM motor on a Ford site.
Old 12-03-2012, 01:13 PM
Harte3's Avatar
Harte3
Harte3 is offline
Well, on any inline engine the #1 cylinder is the first one in the front.
Old 12-03-2012, 01:41 PM
my bad..
My bad, in the future I'll read and pay careful attn to the whole thread b4 chiming in..especially the date..y'all have a grate day
Old 12-03-2012, 06:03 PM
rikard's Avatar
rikard
rikard is offline
I believe every inline 6 is 153624. I know all of mine, even my IH Scout diesel, had the same order. Oldest was a 48 Chrysler Spitfire flathead and newest my 95 300 with a bunch of Chevys, Fords, Mopars, and AMCs in between.
The old mechanics saying was 15 is too young, 36 too old, and 24 is just right.
regards
rikard
Old 12-04-2012, 02:22 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
regards
rikard
As has been said before, it all depends on your point of reference!
Quick Reply: 300 inline-6 firing order????
