Detroit Locker in Sterling 10.5"
#31
Originally Posted by 79schaefer
Well, here is my 2 pennies. I have driven a 1977 F-250 (I know, not a Superduty) for many years with a Dana 60 rear and a Detriot in the rear. The truck is a supercab, with 9" of lift and 39's. I have hauled everything from a snowmobile trailer to a 24' box trailer. Other than when I am really on the gas around a corner, I have hardly even noticed the locker back there. There has only been twice in 7 years of driving on the locker that has done something "unpredictable" Both time involved going down a slight grade with a long sweeping turn on very slippery roads. Both times, the truck kicked out with no power (coasting) applied. Not fun at the time, but far from dangerous.
Steve S.
To many to list.
Steve S.
To many to list.
#32
I had this happen in the same section of road with a truck with an open rear axle before. This particular section of road is bad.
I think that I choose the wrong terminology when I said kicked out. The truck maybe moved over 3-4".
Personally, I would rather drive with a locker in the back in the winter than without.
Just my 2 cents
Steve S.
To many to list.
Just my 2 cents
Steve S.
To many to list.
#33
I'm running a Detroit Locker in the rear of my 05 F350. It has 35" tires and I carry a Lance Camper and tow my boat and it has performed flawlessly. I get my truck off road while hunting and will continue to use this unit. There are some minor road manners like the click, pop, and occasional bang when accelerating after coasting into a turn. I guess it all depends on what you plan on doing with the truck on/off road. If you liked the lockers in the jeep and will get your SD off road then spend the extra bucks and get the locker.
#34
#35
Originally Posted by blackhat620
So when did Eaton start making a Detroit Locker for the 05 & Newer F350 SD?
#36
They didn't "start making the Detroit Locker" they bought Tractech who was the company that was making "Detroit Locker / No Spin / etc." The PN is 225-56SL (I think, don't quote me on that because it's been two years)... Second one I've run in Fords, first one in a 99 and now a 05 Super Duty (same part number)... Fits the 10.25 (old 3/4T and 1 T) and 10.5 (larger ring gear starting in ~99)
So just how are you running the 2004 & older style Detroit Locker in your 2005 F350 SD?
I am well aware that Tractech (originally Thorton Tandem Companies) made the Detroit Locker, but after Eaton purchased all of Tractech's assests in 2005, the Detroit Locker was renamed the Eaton Detroit Locker.
#37
Great to know info but the things you mentioned were from the diff out to the hubs. The diff hasn't changed (other than .25" ring gear) so the unit is still the same... The data you quoted is true for the axles etc. If you want to see mine and I can demo it working...street or with a rear wheel off the ground. Call Randy's Ring and Pinion or 4 Wheel Parts and asked for Detroit Locker (the sticker now reads "Detroit Locker an Eaton Differential") for your SRW...
#39
I have spoken with Randy's R&P, West Coast Diff, Tucson Diff, Eaton and ARB, all of them have told me that currently there are No A/M Lockers (auto or selectable) or L/S units made for the 2005-2008 F350 SD SRW. You must have the only prototype in existance or you don't have a 2005 F350 with a Detroit Locker.
#40
I missed that...YES it does make a difference. My inferior F350 has the "old 2004" Sterling axle in it. (Ford must have tricked me!!! Should I sue for the additional two splines, .14 minor, and .07 major??? What's this world coming too!!!) The PN that is installed in my truck is 225SL-56A which is for a 35 splined axle. I ordered my truck in Feb/Mar 05 so sometimes that happens in the automotive industry - out with the old, in with the new. So to Blackhat...no I'm not a liar, I guess I just got the sissy axles in my truck...but it kicks *** off-road! Thanks for trying to make me out to be a liar. Now before someone gives me some Removed by Admin rendition of how the automotive industry handles parts, save yourself, I don't want to hear it. Ace, you've been in a vehicle with a locker (jeep right?) and it makes a world of different off-road, I'll invite anyone to my area to check out my rig. Bottom line, my truck has a Detroit Locker in it and I love it. Truck has 87+K miles and I'm headed to IL for the holiday season.
#42
Removed by Admin
I'll be back in southern CO for an elk hunt next fall and you're more than welcome to test drive it then...
IF you have the same "old axles" like mine then the unit I referenced should work. Maybe Ford built my truck in 04 with the exact specs I ordered while overseas in Spring of 05, called it an 05 then sold it to me! Maybe the government is behind this...
Last edited by IB Tim; 12-20-2007 at 09:02 AM. Reason: Just pisses me off when someone tries to call me a liar...
#44
As you can see, an Admin removed some of the language ... re-read the guidelines, paragraph 2, if you have to: https://www.ford-trucks.com/guidelines.html
#45
