Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
O5 wont shift from park
Old 12-08-2007, 01:17 PM
ErnieX's Avatar
ErnieX
ErnieX is offline
Hope someone can help,
My son's Escape won't shift out of park when you press on the brake. He says the button on the floor shifter won't depress. Says it feels ike it does when you try to shift without pressing the brake pedal. Anybody have any ideas or suggestions?
Thanks in advance,
EE
Old 12-08-2007, 02:46 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Are the brake lights working?
If not, check the fuse & check the ajustment of the brake light switch.
Old 12-08-2007, 04:57 PM
ErnieX's Avatar
ErnieX
ErnieX is offline
Thanks for the tips, I'll check it out and post back.
EE
Old 12-08-2007, 08:18 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
You can just press the manual override to take it out of park. This allows it to be driven if the switch is broken. the switch is under the steering column
Old 12-09-2007, 06:44 AM
Dan Robertson's Avatar
Dan Robertson
Dan Robertson is offline
My 2005 shifts on the floor. It has a small round cover (about 1/2" in diameter) on the console, right beside the shifter. The owners manual explains the process. Just use a small screw driver and pry the cover off. There is a white button down in there. Use the same screw driver to push that button. That is the manual over ride and you will be able to get it out of park.
Old 01-25-2008, 04:44 PM
iowaescape's Avatar
iowaescape
iowaescape is offline
I just had this problem with my 05' Escape. They had to replace the fuse panel for $206.
Old 06-13-2008, 07:50 PM
GRNMSTR's Avatar
GRNMSTR
GRNMSTR is offline
Another question about the sifter.... I have an '05 and when shifting from Park to Drive it is really rough and noisey and then even when shifting from reverse to drive it is rough getting it to move. It does move but very noisy almost like the shift rails mechanism is dry. Are there any lube points to lubricate the locking unit (the guides) and rails? I had the transmision flushed and that did not resolve the problem. I am about ready to remove the center console and dig in. Nobody has a Haynes manual in stock to purchase and I have ordered it but still waiting for it to arrive. Leaving next Thursday for a meeting in Michigan and don't want anything to "lockup" while traveling. Any ideas???
1999 to 2016 Super Duty
12-22-2007 03:12 PM
ErnieX
12-12-2007 07:21 PM
mlacien
1997 - 2003 F150
09-07-2006 05:15 PM
HoustonF150
1997 - 2003 F150
05-15-2006 07:27 PM
Loctitez1000
Aerostar
09-23-2004 05:31 PM
Quick Reply: O5 wont shift from park
