'97 e150 hesitation/stumbles between 45-55mph in overdrive
Dear Sir,
My 1997 Ford F150 4x4 (77,800 miles) 4.6l does exactly what you described. I am interested in a solution. I have changed my transmission fluid twice. I believe it may be an electrical problem rather than mechanical. Other than this annoying problem, I am really pleased with this well-built vehicle.
How difficult is it to replace the torque converter? May I ask what you paid for this service?
I have had the same problem and it was solved by replacing the torque converter. And, this seems to be a very common problem with this year of F150.
Hope this helps.
Hope this helps.
I finally found the reason for the hesitation problem on my 1997 Ford F150 Extended Cab 4x4 Lariat (79,500 miles). Bad spark plug wire, number two cylinder. I replaced the entire spark plug wire harness system. Truck runs great/smooth. I also had the injection system professionally cleaned/flushed.
Alabadyin
Modular V10 (6.8l)
11-24-2015 12:12 PM
firedad
08-16-2003 01:12 AM
