1999 F250 7.3 charging problem
Out of the blue, my f250 lost charge in the batteries this weekend. I replaced the cranking battery and was able and the problem seem to be resolved. I got the truck back to my house and noticed that the voltage meter was slowly leaking down and bottomed out. The truck would still run but, immediately after shutting off, the new battery was dead.
Will the alternator cause this? or do I have something more serious. I am not familiar with how the dual battery system works. Also, if it is the alternator, how do I know if I have the Single system, or the dual system that the autoparts store keeps asking about?
Thanks
RM
Thanks
RM
First, when replacing batteries, always replace both at the same time.
If you are draining batteries when driving, more than likely the alternator is shot. Get it tested, I'm betting it's not putting out more than 12 volts.
Most trucks have a single alternator setup. So unless you have an ambulance package or something similar, you only have one alternator.
Ok, let me run this by you as well. I could take the positive terminal off the left side battery which is new which the truck kept running. I took the positive terminal of the 2nd battery (right side) standing in front of truck and the truck shut off immediately.
I know normally this would point to the alternator on a single battery system.
What do you think?
Thanks
RM
What do you think?
Thanks
RM
Take both batteries out of the truck at the same time and have them load tested.
The batteries are connected in parallel, so you should be able to disconnect either one while running, and the truck will stay running. Both batteries act as a SINGLE battery, just twice as powerful. To effectively "take the battery out", BOTH must be removed at the same time.
At the age of your truck, I would suspect that maybe your alternator brushes are worn beyond service limits, and the alternator isn't doing as good a job keeping the batteries charged as it might otherwise.
As suggested above, however, it could be simply worn out batteries. If so, replace the pair, not just one.
Pop
Pop
Harley Monster
1999 to 2016 Super Duty
18
03-26-2019 10:00 AM
LipschitzWrath
22
08-14-2017 05:22 AM
Ballerforlife911
16
02-18-2010 06:46 PM
