hoses & seals ???
Old 11-29-2007, 12:03 AM
misnomer's Avatar
misnomer
misnomer is offline
hoses & seals ???
I hear various things about effects of WVO & Biodiesel on fuel lines. How significant are the effects? Is there a place where the varying effects are posted? Viton I hear is the material of choice.. but it is $13+/ft, and I don't think I can get it locally. Tygon (F4040A) is much cheaper $2-4/ft and lots of places carry it. But I have not seen a report about its use with Biofuel.
I have the rear tank out of my truck installed a HotFox, I was thinking of just using standard rubber fuel lines.. but started thinking about the hassel of having to replace the fuel line to the tank again.. I really dont want to be pulling that tank again if I can help it.
How about getting seals for the injection lines for older engines. If I buy a kit will it still be made with OE material?
Old 11-29-2007, 11:58 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
If your truck was made after 1994 you probably already have vitron fuel lines.
If it is older than that you should get them.
While $13/ft is expensive remember it is a one time deal why take a chance on somthing that "MIGHT" work.
Old 11-29-2007, 03:31 PM
misnomer's Avatar
misnomer
misnomer is offline
1984 6.9L F250, no vitron on her. The hard lines are stainless, then the last few feet to the tank are rubber. I just wish I knew a local supplier and didn't have to wait for a UPS shipment again.
The o-rings started leaking also, are all the kits now made with vitron o-rings? or are there some brands I should avoid?
Old 12-05-2007, 09:40 PM
AndysFords's Avatar
AndysFords
AndysFords is offline
Get some good heavy strong rubber lines, and they won't rot away anytime soon.
Old 12-07-2007, 07:19 PM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
It took about a year for a pinhole leak to start in a nice heavy rubber 30R7 line of mine.
Old 12-09-2007, 10:35 AM
DieselFuelOnly's Avatar
DieselFuelOnly
DieselFuelOnly is offline
I use AQP hose made by parker or aeroquip. We use it on ships and it handles everything from hydrualic oil, #2 diesel, JP-5, Lube oil, jacket water... you name it.
Good stuff and its not that terribly expensive.
Old 12-14-2007, 06:28 PM
misnomer's Avatar
misnomer
misnomer is offline
Thanks... it isn't too bad $3.50/ft.. but then I would need to buy fittings for it, corect? or are you able to just slide it on and use hose clamps? The fittings are $5-6 each which doesn't make it much of a cost savings... and I know Viton works.. I ordered enough Viton for the fuel lines from the tank... I might experiment with the return lines.. i can see the return lines having more trouble since they move hot fuel in them.
Old 12-27-2007, 02:26 PM
Fat Diesel's Avatar
Fat Diesel
Had another pin hole leak yesterday. I really need to get the teflon hose installed...
natedog37
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-08-2011 12:00 AM
Midwest Dually
06-03-2010 10:52 PM
derherr65
66
04-23-2007 08:23 AM
BigRed350
08-14-2006 11:25 PM
peterjeff
27
01-21-2005 06:28 PM
Quick Reply: hoses & seals ???
